Old 07-06-2007, 06:09 PM   #1
mnunn454
mnunn454's Avatar
I think I screwed up
Hi all.
Was putting R134a in a friend's early 2000 Chrysler Van last weekend. The first can in contained stop-leak. I loaded it holding the can upside down for most of the time. 2nd can of "non-stopleak" 134 wouldn't go in at all. I then read the stop leak can's instructions (20-20 hindsight is great isn't it?) and it said to discharge gas only (vertical can orientation). My guess is the liquid stopleak stopped up something inside.
Who's done kind of thing before?
It's my mistake and I am willing to pay to rectify the problem. However I'd prefer not to take it to a dealer etc because of the HUGE cost they'll likely sock me with. What are my options?
Thanks,
Signed, Humbled.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 07-06-2007, 06:17 PM   #2
High Speed low Drag
High Speed low Drag's Avatar
Re: I think I screwed up
Stop leak is BAD stuff. I personally check every AC system for stop leak and cross contamination (mixture of R12/R134) before I ever hook my AC machine up.
Hate to say it but if it came into my shop I'd charge around 300 to evacuate it into a seperate recycler for contaminated systems, flush out the entire system, then evacuate and recharge system IF it passed the above tests after all of that.
AC stop leak = bad
High Speed low Drag is offline   Reply With Quote
Old 07-06-2007, 06:18 PM   #3
70GMCer
70GMCer's Avatar
Was the system completely out of freon? If so, you have to vacuum the system down before putting any freon in. I never use that stop leak stuff. I've installed 150 psi of air and then look for the leak with bubbles around where the hoses connect to the compressor and all other connection, and repair. I just finished repairing my sister ac. Turned out to be a leaking O ring at the suction line connection at the compressor. Good luck....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 07-06-2007, 06:45 PM   #4
mnunn454
mnunn454's Avatar
I appreciate the honest replies. I'll know better next time. Lessoned learned.
Moving on to solutions, What do you suggest about the current problem?
Do you think a complete evacuation and recharge will rectify the problem? Or, is there a tiny orifice somewhere that's most likely plugged?
Or, did the stuff probably clog the filter/drier and replacing that will likely remedy the problem.
Thanks.
Old 07-08-2007, 08:40 AM   #5
mnunn454
mnunn454's Avatar
Ttt
Old 07-08-2007, 09:45 AM   #6
70GMCer
70GMCer's Avatar
I would at the very least replace the dryer and evac and then recharge and hope for the best. Also tighten all the hose fittings, being careful not the over tighten them.
1997 GMC Sierra Ext
1965 Mustang
Old 07-08-2007, 11:36 AM   #7
72CSTC5
72CSTC5's Avatar
Disassemble the system, replace the drier, orifice tube and expansion valve if it has one for the rear a/c. Blow out the system real good and see how far and where all that stop leak got too. Reassemble if ok, pull a vacuum and add some oil and recharge and cross your fingers!
72CSTC5 is offline   Reply With Quote
