Old 07-06-2007, 08:39 PM   #1
scotts 72
shock relocator
I put 4" drop coils on my 72 c-10 and it rides rough.It seems to me that the shocks are possibly bottoming -out.I saw a shock relocator kit on some of the part suppliers web pages and was wondering if any one out there has any info/ feed back on how well these work as opposed to shorter shocks. Thanks
scotts 72 is offline   Reply With Quote
Old 07-06-2007, 09:13 PM   #2
Wild83C10
Wild83C10's Avatar
Re: shock relocator
I too am looking for a shock locator. I have lower tubular control arms with lowering springs. I also purchased shorter adjustable shocks and they bottom out on very hard bumps. I saw a shock relocator on the air ride site under their new C10 suspension system. I don't see it listed as a separate item, but I have been meaning to contact them on this.
http://www.ridetech.com/productinfo/c10.asp#
Is there anything else out there?
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 07-06-2007, 09:29 PM   #3
Kontrol Phreaks
Kontrol Phreaks's Avatar
Re: shock relocator
I'd look into a shorter shock before you get into modifying the truck to make your current shock work. If you want to get me some measurements then i can research my shock book and see what's available and provide you with some part numbers.
Good luck with the project.
- Clint -
Kontrol Phreaks is offline   Reply With Quote
Old 07-07-2007, 07:45 AM   #4
cdowns
cdowns's Avatar
Re: shock relocator
when lowering the rear of the truck you're laying the shock down loosing its effectiveness(they're designed to work best up and down not sideways) and you also need to go for shorter shocks
Old 07-07-2007, 11:21 AM   #5
orange72c10
Re: shock relocator
I lowered my 72 c10 last year a little and put drop shocks on the truck which are shorter than stock, but there was no travel left in the shock even with shorter shocks. This year put a shock relocator kit which uses your stock holes and also putting an adjustable panhard bar in the back to re-center your rear axle. I bought my kits from http://www.classicperform.com and a lot of guys on here buy stuff from http://www.earlyclassic.com, you would be surprised how much your rear axle moves off center from lowering it. Good luck.
orange72c10 is offline   Reply With Quote
Old 07-08-2007, 01:55 PM   #6
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: shock relocator
For the rear, you can take the stock lower brackets, heat and beat the lip of them flat and then flip them side to side and upside down to get 2-3 more inches for your shock.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 07-08-2007, 04:58 PM   #7
SCOTI
SCOTI's Avatar
Re: shock relocator
You'll only gain about 1.5". But, that's a fair amount for free if you do it yourself.
Modify the top brackets & you'll gain another 1~1.5" of travel depending on how high you re-drill the top shock hole & whether or not you 'reverse' the brackets F/R orientation.
For about $70, ECE, P.O.L, & CPP does the fabricating for you.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
