Old 07-07-2007, 12:04 PM   #1
JPSAUTO
Steering Help Anyone
Wanted to cleanup the lower steering shaft and put a new seal in what GM calls the pot joint or coupler joint (opposite the rag joint). Question is will the cross pin the two bearings ride on press out of the shaft. I did put some pressure on it (will a press) but saw no movement. Don't want to mess it up. Also where can I find a new seal. Oh yeah it's a 69 1/2T 2wd. Thanks.
JPSAUTO is offline   Reply With Quote
Old 07-08-2007, 07:58 AM   #2
JPSAUTO
Re: Steering Help Anyone
Anyone
Old 07-09-2007, 04:53 AM   #3
JimKshortstep4x4
The service manual says to use an arbor press to press the pin out and not to drive it out with a hammer. So, according to the manual the pin can be removed by pressing it out.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
