Old 07-07-2007, 06:53 PM   #1
Morgsie
Dana 60 brakes
According to the guy who sold my buddy his 67 C20 (8-lug), he swapped in a Dana 60. I've briefly glanced at the pan, and it did indeed look like a Dana 60, but I can double check tonight. Anyway, how would a guy go about ordering brake parts for it? Are they stock brakes or off of something else? I've also been told that you need to pull the axles on this diff to change the brakes, is this true? If so will I have to drop the pan, or do the axles just pull out once unbolted from the outside?
Morgsie is offline   Reply With Quote
Old 07-07-2007, 07:07 PM   #2
eedgell
It's the air up here
eedgell's Avatar
Re: Dana 60 brakes
I assume your talking about the rear axle? If so parts from NAPA or where ever should be easy enough to get. Yes, you must pull the axles for a brake job, but not the pan.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 07-07-2007, 07:11 PM   #3
Morgsie
Re: Dana 60 brakes
Ah, yes, sorry I didn't say that it was the rear diff. Did these trucks come stock with a D60? Everytime I go to a parts place (Napa or otherwise) they always need make/model/year before they can search for stuff! I'm just wondering what truck this would have came off of so it won';t be a big hassle to get brake parts.
Old 07-07-2007, 07:17 PM   #4
eedgell
eedgell's Avatar
Re: Dana 60 brakes
Well I am guessing that it might have come from a 1ton, unless the spring pearches have been moved. Then it could have come from a ford for all we know.It would have to be 1973 and up. These trucks 67-72 in 3/4 ton came with eaton ho52 rears.
Eric
Old 07-07-2007, 08:37 PM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Dana 60 brakes
Some like mine came with Dana 60,and it's been so long I can't remember if the axle has to come out,( I don't think so) but if it does it just slides right out after you unbolt it on the outside. I've seen Dana 70s on 1 tons.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 07-07-2007, 11:57 PM   #6
Twistedsteel
Twistedsteel's Avatar
Re: Dana 60 brakes
Yep my buddy has a 70 Gmc 4x4 and it has a dana 60 rear in it. Maybe only some of the Gmc's came with them.
Albie
Twistedsteel is offline   Reply With Quote
Old 07-08-2007, 12:17 AM   #7
1969k10stepside
Re: Dana 60 brakes
Chevys had the eaton and GMCs had the Dana 60 rear.There is a few exceptions but thats the general way it goes..
1969k10stepside is offline   Reply With Quote
Old 07-08-2007, 01:15 AM   #8
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Dana 60 brakes
My 72 3/4 ton came factory with a Dana 60 rear. Also on the Dana you do not have to pull the axles. Just pull the drums off...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 07-08-2007, 06:41 AM   #9
Blazer1970
Blazer1970's Avatar
Re: Dana 60 brakes
If you can get the BOM number off the axle tube, it will tell you the original year and application of the axle.
Blazer1970 is offline   Reply With Quote
