Old 07-07-2007, 07:14 PM   #1
jkade
jkade's Avatar
Are 67's boosters different?
The booster is bad on the 67 I bought so I called the parts store and they got me one. When I picked it up from the store I knoticed it looked the same as the one on my 72 blazer. The one on the 67 is smaller in diameter and thicker than the one they ordered and the 72. Nedless to say it didn't work, the rods are longer on the new one and when I got it bolted up the master cylinder would not go back on the studs because of the longer rod. What do yall think????/
jkade is offline   Reply With Quote
Old 07-07-2007, 10:30 PM   #2
sakohntr
sakohntr's Avatar
Re: Are 67's boosters different?
Yes, its different. Look for a good used one. Or convert the entire assembly to the 72 style. Keep in mind the 3/4 ton uses a HD booster with is thicker
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 07-07-2007, 11:40 PM   #3
jkade
jkade's Avatar
I was thinking about buying a kit from cpp that has the booster, master, and a disc/disc porp valve. It comes with the brackets and the rod that mounts to the pedal, I guess that will work won't it?
Old 07-08-2007, 01:46 AM   #4
rdporterjr
Keep us posted on how that is going. I'm considering doing the same with my '69. It already has discs up front but I would like power brakes.
thanks...
'69 SS
i.e. '69 Chevy Short bed Step side
rdporterjr is offline   Reply With Quote
Old 07-08-2007, 04:39 PM   #5
bad_turbo
turbo enthusiast
bad_turbo's Avatar
My booster was bad on my '67 burb and I bought a 4 year old master cylinder/booster combo from a member that had it on his '69 truck, and it bolted up and worked fine. Took about an hour to do and the booster is different than my '67 was.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
