That damned dipstick tube!
Does anyone have any tricks for keeping the dipstick tube from pulling out?
Dark Heart Motorsports
Re: That damned dipstick tube!
Room Temperature Vulcanized sealant...
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
The One And Only !!!
The tube is a press type fit into the engine block, If yours is loose it would be best to replace it with a new one.
They are not very expensive.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
OK, thanks guys! I'll try the RTV first, then if I have to I'll replace it.
Parts and more parts
All else fails, have someone braze a little thin brass onto the tube end and then with the extra metal insert it ito the hole.
A short-term fix is to take it out and tap the bottom into a slightly oval shape that becomes a press-fit into the block.
If you have a double-flaring tool, you might be able to use it to barely upset the bottom so it fits tighter. |
