Need Help With Hooker Trouble
Need suggestions
Can't get drivers side Hooker 2452's to clear The first try Header hit crossmember so rear of header flange was to high. I replaced motor mounts which helped but also had to added about 3/4" spacer under tranny mount to clear crossmember. (1st Photo is before I added spacer) I can now get all the bolts in, but header is hitting the frame rail so the top of the header flange is angled out further than the bottom. I think I can grind the frame rail some to get clearance. But from reading posts on headers the Hooker 2452's should have fit better than this. Also will raising the tranny 3/4" cause any problems since angle of drive shaft changed. Pleased let me know if you have any thought on getting these to fit. Or should I send them back to Summit and try something else. Thanks WT |
Re: Need Help With Hooker Trouble
What year truck is this? 4X4? or 2X4? If it's 2X4 is it Lowered? Are those long tube headers? I have Ceramic Hooker super competition "shorty version" & they fit perfect on my 71 C-10 that is very low, they tuck up higher then the crossmember.
70 2WD, 350/350, lowered some.
These are long tube Hooker Comp. I read a bunch of the header threads before I decided on these. All said the fit was good, not sure whats odd about mine. WT |
This likely isn't much help but I have these on my '72 C10 and there were NO fitting issues at al other than having to adjust some brake lines and the fuel vapor return.
EDIT: My motor mounts are in the front hole as well. Is there any way the engine could be shifted towards the driver side (?) Mine really aren't tight at all; I'm happy to post pictures if it will help...maybe left/right clearance? Last edited by Billla; 07-08-2007 at 08:04 PM. |
Would it make any difference of which motor mount holes you used? I know there's 2 sets of holes, not sure if would fit better if your in the front holes or the rear holes, maybe Billa can elaberate on this, I know he's very knowledgeable on these trucks, maybe some guys can post some pictures of their setups & maybe something will show up to explain it. I can post mine, but their shorty's, so I'm not sure if it would be helpful to you.
It's the air up here
Header trouble? Try stock manifolds. They fit right every time. Not much gain with the header set up unless a hot rod car and your gonna run pinks light to light. Get a hammer a dent those tubes. Thats how the big boys do it.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
![]() Join Date: Jul 2004
Looks like mounts are in the correct front position, I don't know man, I am getting ready to get headers from hooker too from what I heard they fit good but.........hope someone has an answer.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#9 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=248273 As for "clearancing" the pipes...last resort IMHO. |
______________
![]() Join Date: Sep 2006
OH!! Headers. Made me look.
I once had some problems with some hired help in Vegas. Kidding. ![]() Last edited by sighlurr; 07-08-2007 at 08:11 PM. |
67-72 Addict!
Those headers look great!. Sorry to hear about the fitment problem. At this point I would probably grind a little off the frame rail and be done. I have Super Comps #2808 on mine and they fit great.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Any updates on what is wrong, those are suposed to fit nice, could it be a mis-made set ????
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 07-09-2007 at 11:06 PM. |
#13 | |
Location: vacaville ca, because it as far from indy as i can be
you can also try and find some of the motor mount shims/spacers/plates the 73+ and others sometimes used a steel plate between the block and mount. i would suggest pushing the deal backward and re drilling your motor and trans x members. i have mine pushed back about 1" and it helps in so many ways. |
#14 |
#15 |
Hey I got Hooker 2452s on my 68 BB and they look a little different than those. Had no clearance at all. They slip right in and out. Here are a couple of pics.
1968 Chevy shortbed fleetside Pro Street |
#16 |
Licensed to Thrill!
The topic of this thread - and then the last poster name I saw was this guy above me...
You guys put it together - I got a laugh. DLB Last edited by Orange; 07-11-2007 at 03:14 PM. |
#17 |
![]() Join Date: Jul 2001
Hey our US senator has hooker trouble.
11 Surbaban 70 C 10 still in progress |
#18 |
Boy, did that come out all wrong. Guess I better read what I type next time before I post it. Sorry.
#19 |
Licensed to Thrill!
![]() I didn't even really read your post that in depth, until just now. WOW! This one is on the verge of being un-family friendly. ![]() DLB |
#20 |
i had a bit of trouble getting my headers to fit.
turns out when my tranny was re-built, a new mount (that was different) got put on. the motor had to move a little further back (1/4 inch or so) so i just slotted the tranny mount bolt holes on the crossmember. it was very simple to do, the crossmember basically falls out. HOWEVER my truck is not lowered. 2wd 350/350 though.
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
#21 |
Official Site Guitar Shredder
i had hooker trouble one time dam her,sorry i couldnt resist
