Old 07-08-2007, 06:38 PM   #1
shifty
Questionable
shifty's Avatar
bezel swap: headlight dash hole?
i just gutted the stock wiring out of my truck to rewire with something more modern. everything is getting rewired for the LS1.
in the process, i am swapping from a 3-hole dash to a 7-hole dash.
problem: there are four provisions for switches on the dash. the headlight switch is in a different place on the 3-hole dash and 7-hole dash, and it has a unique 'keyhole' opening. well, the hole i need to put the headlight switch in isn't hkeyhole shaped
question: i realize i can get a dremel and file and grind/file my dash to put the headlight switch in the proper place for my 7-gauge bezel, but ... anyone have any tips to make the job easier?
if not, cool. i'm not sweating it and can't do it till tomorrow, so ... i figured i'd ask now.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 07-08-2007, 09:57 PM   #2
jkade
jkade's Avatar
Re: bezel swap: headlight dash hole?
They ring has enough threads that it will still screw in without the tab cut out. I just did the swap on my 67 and I just did it without cutting the little tab out. Hope this helps.
jkade is offline   Reply With Quote
Old 07-08-2007, 11:02 PM   #3
shifty
Questionable
shifty's Avatar
I tried doing it earlier and had zero luck. I think my hole might be a little tighter than yours?
