huh?
![]() Join Date: May 2000
Power brake guys???
Hey all,
I added power brakes to my 68 a while back, when I did the disc conversion. I also got two support bars for the booster. One is a round bar, the other is flat, they're both curved at the ends, where do they go? Any one have pictures? Thanks in advance.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
its all about the +6 inches
Re: Power brake guys???
a bump TTT for my friend... even though he didn't make it to Norwood.
Here is a picture of a 71 setup. It is probably different from the 68 but it is all that I have.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
![]() Join Date: May 2006
I took a snapshot of mine before I took it apart, I got old timers disease.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
huh?
Thanks for the pics guys, I'll take a look and see if I've got the holes for the other end of those brackets, being it's not a power brake truck originally. At least I have a good idea where they go now.
Thanks again. There's no place I'd have rather been man, trust me.
TJ, you probably won't have the holes. IIRC, the braces showed up in 71.
Son of a gun
they go to existing bolts. IIRC, the flat one goes to the top bolt that holds the sheetmetal collar on the bottom of the steering column, and the round one goes on the top bolt of the e-brake assembly.
Bill BEATERS ARE NEATER |
I looked at a 68 today and there were no mounting holes for the braces. I believe the braces came later than 68.
The 68 has a hand brake so there are no studs sticking out for the rod to attach to. On my 71 the mounting hole with the built in nut is in the firewall below the steering collar as seen in the picture. If you want to use the braces on your 68 it appears that you will need to locate and install the attaching points. If you want any measurements for the attachment locations, let me know and I will get them for you. Jim
I put the braces on my 67. The flat one does in deed go to the firewall where the column exits the cab. One end is at the MC (on the outside if i recall) and the other end mounts to one of the 3 bolts that hold a tin to the firewall. The rod mounts from the outside edge of the booster bracket to a through bolt (I had to add this on my 67) located near where the cable exits the cab.
Also 1 other point - there are long supports and short supports depending on what style of mounting brackets you have. You must have the proper items all the way around. And I also think(know) they weren't used in 67/68. Not sure about 69/70. And am quite positive they WERE used in 71/72. But however a good addition if you don't have them. I recommend them. Hope this hasn't muddied the water too much - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
