Old 07-08-2007, 09:04 PM   #1
one9six9
Junior Member
Sliding Rear Glass
Does anyone make a kit to replace the felt, or seals in the rear sliding glass? Mine rattle like crazy. The truck would be as quiet as could be if they didn't rattle so bad.
Keith
one9six9 is offline   Reply With Quote
Old 07-08-2007, 09:40 PM   #2
67CHIP72
STOLEN
67CHIP72's Avatar
Re: Sliding Rear Glass
I had the same problem. I was told to look around at RV shops, which makes sense. When I got my windshield replaced I asked if they had any molding lying around as I only needed it for the top. No luck. I eventually came across a whole other original slider for cheap. Pulled the felt out and put it in mine. I put the rest of the window up in the rafters as I'm sure I'll need another part or glass from it later on. Good luck, let me know if you find a newer replacement.
In Search Of
67CHIP72 is offline   Reply With Quote
Old 07-08-2007, 09:58 PM   #3
RV supply would be a good bet.I wonder of Steele Products would carry a channel like that.I wonder if the door window channel could be made to work.There`s got to be a resource that deals in various seal/channel type supplies.The window companies buy from someone.
Old 07-08-2007, 10:06 PM   #4
71tahoe
71tahoe's Avatar
Maybe they will have what you need here. http://www.crlaurence.com/ProductPag...::17381::19748
71tahoe is offline   Reply With Quote
Old 07-08-2007, 10:09 PM   #5
hutch949
I went to auto glass shop and they had exactly what I needed. Hutch949
hutch949 is offline   Reply With Quote
