Old 07-09-2007, 11:19 AM   #1
67ChevyRedneck
67ChevyRedneck's Avatar
Anyone used a Painless Remote starter solenoid?
Like this?
Trying to fix ALL of my trucks issues, and "hot start" is one of them. I hope this will be a permanent fix. Anyone used this kit? Is it any good? Where's a good place to mount it??
http://www.partsamerica.com/productd...goryCode=2103A
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-09-2007, 12:10 PM   #2
fatboys69
fatboys69's Avatar
Re: Anyone used a Painless Remote starter solenoid?
didn't use the Painless Kit, I just went to the parts store and got a Ford soleniod, ( already had wire and teriminals ), It's and easy modification that works great !!! Glad I did mine, helps starting during the hot summer months.
fatboys69 is offline   Reply With Quote
Old 07-09-2007, 12:18 PM   #3
Ackattack
Ackattack's Avatar
I used it. I mounted it to the inner fender near the starter.
You could probably find a cheaper one and just run wires yourself....but if you get the painless one its all there.
Definatly nice to have though!
Ackattack is offline   Reply With Quote
Old 07-09-2007, 03:02 PM   #4
dmec
dmec's Avatar
Ford relay
dmec is offline   Reply With Quote
Old 07-09-2007, 03:19 PM   #5
Orange
Licensed to Thrill!
Orange's Avatar
If you decide to go that route - Jegs is cheaper.
http://www.jegs.com/webapp/wcs/store...10002_73864_-1
My dad put one of the Painless "hot shot" relays on his (not the remote solenoid) - and it literally popped it.
I have no issues with mine. "If ain't broke..."
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 07-09-2007, 03:27 PM   #6
67ChevyRedneck
^It's cheaper until Jegs adds 11.99 for shipping. Advance will ship it for free
Jesse James
Project "On a Dime"
Old 07-09-2007, 03:29 PM   #7
67ChevyRedneck
Thanks for all the feedback all. I think I'll order the painless kit. I've spent so much $$ on this damn truck, whats another $40 for a complete kit? I get tired of 2 or 3 trips to the parts stores (closest one is about 20 mins if there's no traffic ) Wiring is NOT cheap anymore either!
Jesse James
Project "On a Dime"
Old 07-09-2007, 04:23 PM   #8
Orange
Licensed to Thrill!
Orange's Avatar
Ehh - I usually buy enough stuff to well cover the shipping. Plus, it's here in 2 days - which beats most places 1 week shipping.
Good luck getting everything how you want it.
DLB
Old 07-09-2007, 05:15 PM   #9
2bits
2bits's Avatar
What do you do with your existing solenoid? I would think you would have to have it there still to hook the wires to, but then what's the point if it is still there. Do you get a different starter too? Sorry for my ignorance.
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 07-09-2007, 05:21 PM   #10
67ChevyRedneck
Good question! :lol
I think you remove the old solenoid from the starter and connect the new wires where the old ones used to go, so no more heat soak into the solenoid. I hope that's all it is
Jesse James
Project "On a Dime"
Old 07-09-2007, 07:47 PM   #11
mnunn454
mnunn454's Avatar
GM combines two parts into one, the heavy duty "switch" and the electromagnet that presses the bendix gear into the flywheel. Ford separates these two components, moving the H/D switch to the firewall.
What's confusing is both setups are commonly referred to as "solenoids".
Besides the "brand insult", when you add the Ford firewall solenoid to the GM setup you're only (in effect) moving the heavy duty switch part and wiring away from the exhaust. The GM magnet that pulls the gear into the flywheel stays where it is and is subject to the same heat problems as all other starters.
If the hot start problems posted above were HD switch (solenoid) related, the remote Ford Solenoid approach will solve it well (just hide it under the heater box please). If it's bendix/magnet or hot starter dragging related it won't.
Hope this helps.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 07-09-2007, 08:01 PM   #12
72hotrod
72hotrod's Avatar
I just took a piece of flattened 1/2 copper tubing, drilled holes for battery stud and solenoid start post,bent and shaped it a bit and bolted it in place. When the F*rd solenoid sends battery current to the GM starter, the GM solenoid kicks in, too. I've done this for years, and I always run headers without any weak starts when hot(as long as the starter motor isn't wore out).
72hotrod is offline   Reply With Quote
Old 07-30-2007, 10:52 PM   #13
67gmcss
I see the above pic about how the solenoid looks on the fender, but does anyone have a diagram or schematic or idea or whatever about where all those wires are running to? I went to a local cruise this past saturday and could hardly get the truck to start any time i shut it down. I bought a ford solenoid at advance auto the following Sunday, but it came with no wires or instructions whatsoever. Any help greatly appreciated.
67gmcss is offline   Reply With Quote
Old 07-30-2007, 11:31 PM   #14
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Ask and you shal receive.
http://www.novaresource.org/starter.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-04-2007, 10:34 PM   #15
72hotrod
72hotrod's Avatar
This is the way I do the F*rd setup.There is a short cable from battery POS post to one side of F*rd solenoid.On the other side all you have is the cable to the starter cable stud. This cable will only carry current when the F*rd solenoid is energized. No wiring is using the cable stud on the starter as a junction, just a flattened copper tubing jumper from the cable stud to the start terminal of the starter solenoid. The "S" terminal of the F*rd solenoid is 12 ga to the fuseblock firewall connector where the START wire comes out. Put on a ring terminal at the solenoid end and a Packard 56 series male crimp terminal at the firewall end. Unbolt the fuseblock connector and unplug the old START wire terminal and plug in the new 12ga. Sorry I don't have any pics or links, but it is not too hard. The hardest part for me was finding the Packard terminal.
