Old 07-09-2007, 03:33 PM   #1
Rascal_one2001
Rascal_one2001's Avatar
dumb question about d44 and corp.10
this may be a dumb question but what is the differance in the dana 44 8.5 ring and pinion and the corprate 10 8.5 ring and pinion. I havent really messed with the dana 44's much before and was wondering whats the differance in the gears.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 07-09-2007, 07:01 PM   #2
msgross
msgross's Avatar
Re: dumb question about d44 and corp.10
I have a thread on the differences in the axles, the ring and pinion seem to be different as well. I know that mine had a different spline count 30 vs 28.
http://67-72chevytrucks.com/vboard/s...d.php?t=240456
Dana Spicer D44
View Parts List
10 bolt cover with 8.5" ring gear. Found in both front and rear applications. Rear applications use a bolt in axle. Axles are 30 spline. Front applications came in both standard and reverse rotation.
Ring Gear Diameter: 8.5
Ring Gear Bolts: (10) 3/8 x 24 RH
Cover Bolts: 10
Carrier Breaks: 3.73 / 3.92
Spline Count: 1.375 / 26
Float: SF or Front
Semi-Float Type:
Pinion Support: False
GM 8.5
View Parts List
10 bolt cover with 8.5" ring gear. Ring gear has 10 bolts and pinion has 30 spline. C/clip rear could have 28 or 30 spline axles.
Ring Gear Diameter:
Ring Gear Bolts: (10) 7/16 x 20 LH
Cover Bolts: 10
Carrier Breaks: 2.56 / 2.73
Spline Count: 1.625 / 30
Float: SF
Semi-Float Type:
Axle Lugs:
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-09-2007, 08:17 PM   #3
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
the pinion shank is thicker on the 10b
trkklr77 is offline   Reply With Quote
Old 07-09-2007, 09:03 PM   #4
msgross
msgross's Avatar
looks like the ring gear bolts are different as well...
As far as dependability goes, they are equal axles. Both have disadvantages if you are into hard-core 4 wheeling. For the average user then you can go with either.... The spline count on the inner axle is different and the wheel hub bearings are different (larger spindles on 10b) but those issues don't matter much.
I actually have a 10bolt with dana44 spindles and hubs on my 68.
The Garage:
Old 07-09-2007, 11:14 PM   #5
trkklr77
trkklr77's Avatar
the 1/2t-3/4t 10b spindles are the same as all d44 3/4t and 76/77 1/2t.
dont even start about the axle splines. they both neck down to 1.1" reguardless of the 28/30 or d44 30.
Old 07-10-2007, 07:01 AM   #6
msgross
msgross's Avatar
I disagree on the spindle part...
I have an 82 corp 10 bolt 1/2ton and agree that the spindles might be the same as a Dana44 3/4 ton.... but I also have a 76 1/2ton dana44 and it's spindles are smaller....
The Garage:
Old 07-10-2007, 09:26 AM   #7
Rascal_one2001
thanks for the info guy.
Old 07-10-2007, 09:31 PM   #8
trkklr77
trkklr77's Avatar
the spindle change is in the area of 76/77 some are some arent, same as when people say the d44 went to 10 77-78-79 the could have either.......
