![]() Join Date: Apr 2007
Mounting bed with no floor
It's been a few years since I removed the bed from my truck and I'm finally ready to re-install it... well, minus the wood floor (cause I'm itching to drive it!) Can someone sell me if the wood runs between the bedsides (fleetside) and the mounts on the cross sills.
Thanks, Tony |
Re: Mounting bed with no floor
Yes the wood runs from bedside to bedside, and bolts to the cross sills.
So can I just bolt the bedsides directly to the cross sills or do I have to shim it 3/4" or so (where the wood would normally go) to get the bed to sit at the right height?
You will need to shim it 3/4 to allow for the wood.
gotcha, thank you for your help!
-Tony |
65 - Chevy C10
Ahh.. what do you plan to use for shimming it? I will need to do this also.
I would get some 1x4's, and bolt them to the cross sills that way it would pick it up to the level you need. Don't use pressure treated lumber because the new chemicals in the wood eats through metal.
I ended up buying some 3/4" steel square tube - cut it to length and drilled some holes - seems to fit perfect and added support across the cross sills.
Cool, thats sounds good!!
65 - Chevy C10
What do you mean by added support across the cross sills? Can you send pics of how you did it? Thanks.
The bedsides mount to the cross sills at 3 points and then to the rear cross sill (shortbed). I bolted the bedside mounting flanges to the square tube so it rests across 2 cross sills so all the weight of the bedsides isn't being supported by just the mounting flange at each cross sill. Basically takes the place of the wood that would normally support it - probably overkill, but it was cheap and easy insurance. I'll try to snap a few pics tonight.
I just finished repairing the bedside flanges. When I bought my truck it had no bed or shims and the stress at the cross sills caused them to rip.
#13 |
#14 |
MAR-K sells repair flanges to fix them. Here is a link.http://www.mar-k.com/catalog/catalog.asp
#15 |
Truck Parts Mfg.
![]() Join Date: Jul 2005
This link will take you directly to the descriptions of all the bedside repair panels. http://www.mar-k.com/what_s_new_at_mar-k.html
Mar-Ktech
GET MAR-K Quality! Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks |
#16 | |
http://www.horkeyswoodandparts.com enter the site and on the left hand side choose "Chevy", it will come up with a list of subcatagories, the second on the left is "Boxsides" and within this group you will find the "Fleetside Repair Angles"
________________________ 62' ![]() 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 Last edited by 62ChevyStep; 07-12-2007 at 01:17 PM. |
