Old 07-09-2007, 07:55 PM   #1
bglad420
bglad420's Avatar
5 lug swap Q's
OK I have a 70 GMC 1/2 ton with drums on all four. rear leaf springs. I tore the guts out of my rearend a while back for my Blazer. Now the blazers gone, and I need a rearend. A guy has a 78 12 bolt rearend. I know the centersection swaps, but what about the axles?? I know I'll have to change all the brakes over too. But heres my main Q he called me today and said I can have the front parts too, they are disc brakes. Will they bolt up?? Pretty new to forum and searching is a bit confusiong for me.
Thanks!
bglad420 is offline   Reply With Quote
Old 07-09-2007, 08:07 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 5 lug swap Q's
It will all bolt up.There should be a complete write up on several different ways to do it with those parts.It will be located in the FAQ's section and will go into much more detail than anyone can here.Basically you can use the control arms out,or you can swap the whole front crossmember under your frame.Lots of options depending on whether you want PS and PB also.I think you can use just one set(uppers or lowers of the control arms)and if available the sway bar will work.Good luck and enjoy the benefits you get.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-09-2007, 08:47 PM   #3
Ackattack
Ackattack's Avatar
Re: 5 lug swap Q's
I have a whole 5 lug front suspension and rear axle for a pickup too. Let me know if you're interested.
Ackattack is offline   Reply With Quote
Old 07-09-2007, 08:58 PM   #4
bglad420
bglad420's Avatar
Re: 5 lug swap Q's
I have a guy who has the stuff on a truck locally but thanks for the offer, he said he'd sell me the whole package for 250, rearend tire to tire, ALl front end components too, my truck has a 402 BB, with PS, and PB but drums on all four. The searching is leaving me really empty handed, if some one wouldn't mind posting the links to the swaps that would help me out alot.
