Old 07-09-2007, 08:48 PM   #1
deer slayer
disc brake an eaton
has anyone disc braked an eaton rear and if so where do you get the kit fromn thanks jeff
deer slayer is offline   Reply With Quote
Old 07-09-2007, 10:27 PM   #2
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: disc brake an eaton
I don't know much about doing it, but I would think a '72 Eaton would use the same parts to do it as the '73- up, as the '72 rear has the newer style drums. I'm curious to know too.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 07-10-2007, 01:49 AM   #3
EFI70Blazer
Active Member
EFI70Blazer's Avatar
The same kit you would use for a 14 bolt full floater also works for an eaton.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 07-10-2007, 04:14 PM   #4
deer slayer
ok thanks
Old 07-25-2007, 11:42 PM   #5
customcamper72
so a eaton & a 14 bolt have the same backing plate mounting patteren?
customcamper72 is offline   Reply With Quote
Old 07-26-2007, 12:04 AM   #6
pumpkin
pumpkin's Avatar
I put them on mine, but I just made my own caliper brackets. I used front brackets and welded them to a flange that bolts to the housing where the backing plate was.
pumpkin is offline   Reply With Quote
Old 07-26-2007, 01:14 AM   #7
drink2mny
drink2mny's Avatar
We are an option..
We make a kit for the Eaton rear...
http://www.blackbirdscustomtrucks.co...x7.html#5eaton
take a look around.
Support The Board
drink2mny is offline   Reply With Quote
Old 07-29-2007, 12:37 AM   #8
wibilly
wibilly's Avatar
i did mine i used 14 bolt caliper brackets but if i were to do it again i would just weld front brackets on. 4wd front roters. i used caddy calipers for the parking brakes
common sense isn't so common anymore
wibilly is offline   Reply With Quote
