Old 07-09-2007, 10:00 PM   #1
ScottH
ScottH's Avatar
Need to know stock wheel width 68 C20 16" rims
Can anyone tell me the wheel width for the stock wheels on a 67 C20 with 16" rims? I want to replace the tires from 235/85/16 to 265/75/16 but not sure if the stock rims are wide enough for the wider tires.
Any help is appreciated.
Thanks.
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 07-10-2007, 10:08 AM   #2
ScottH
ScottH's Avatar
Re: Need to know stock wheel width 68 C20 16" rims
Anyone?
Old 07-10-2007, 03:23 PM   #3
manimal
manimal's Avatar
You can use a 6.5-7" rim for those tires. They arent that wide. I think the stock late model wheels are 6.5's
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-10-2007, 03:33 PM   #4
ScottH
ScottH's Avatar
Lance, thanks. Trying to figure out if they will fit on the stock 67 rim.
Scott
Old 07-10-2007, 04:49 PM   #5
manimal
manimal's Avatar
The stock wheel I "think" is a 16.5. I may be wrong, but I dont believe they had 16" wheels in '67. If they are 16.5's then use a 9.50x16.5 radial tire.
-Lance
BTW look on the rim around the outer lip and it will usually tell you the size.
-Lance
Old 07-10-2007, 06:07 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if it is a 16 inch, then it's a split rim, and should be thrown away in all reality. You probably wouldn't even find a tire place that'd even consider doing that.
Old 07-10-2007, 06:08 PM   #7
ScottH
ScottH's Avatar
How can I determine if it's a split rim?
Thanks.
Old 07-10-2007, 06:15 PM   #8
JAKES 68GMC
Aluminum slot wheels rule...
If its a 2-piece rim with a lock-ring, it a split rim. if its a one piece 16in. rim, then your all set, 265s will mount fine.
JAKES 68GMC is offline   Reply With Quote
