Old 07-09-2007, 10:10 PM   #1
bighead
6 Lug???
Does anybody know if a regular 6 lug 2wd wheel will bolt onto a 6 lug 4wd front spindle?
bighead is offline   Reply With Quote
Old 07-09-2007, 10:12 PM   #2
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: 6 Lug???
If the hubs are the same opening (center hole of wheel) should work fine as long as its a 6x5.5 bolt pattern i believe
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 07-10-2007, 12:41 AM   #3
wibilly
wibilly's Avatar
Re: 6 Lug???
i would think so. the only problem i ever had was some older rims for drum breaks would not clear the calipers on disk breaks, but that was on cars not sure if it is a problem with these trucks or not
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 07-10-2007, 12:54 AM   #4
sdkid
Re: 6 Lug???
I can tell you that 67-70 drum rims will not bolt on 78 4x4 front discs without gouging the rim and caliper
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 07-10-2007, 04:05 AM   #5
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: 6 Lug???
providing they are ment to clear disc brakes then yes theyll work
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-10-2007, 07:28 AM   #6
mrein3
mrein3's Avatar
Re: 6 Lug???
6-lug rims that came on factory disc brake trucks will fit both disc and drum trucks. 6-lug rims that came on a factory drum truck WILL NOT FIT over the front calipers.
Like sdkid pointed out, your older 6-lug rims won't work on a 78 4x4. However, the 4x4 rims off that 78 will work on your 70 front or rear.
Same thing with 5-lug car rims. My 14" ralleys that I got on my 1972 Chevelle when I bought it (front disc brakes were an option in 72 on Chevelles) won't fit on the front of the car now that I installed disc brakes.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
