Old 07-10-2007, 09:40 AM   #1
wildmanaaron
Ls-1 Swap Question-for Those Who Have Done One
For those of you who have swapped an LS-1 engine into their 73-87 era Truck; what type of accelerator cable did you use. I have been told from another website to use the original "Camaro" style accelerator cable that this engine is out of, but that it "may" be too short for my application. I would rather ask around then spend the money from GM for a part that doesn't work.
Also FYI, the Corvette fuel rail covers that go on the LS-1 engines fit a little snug on the driver's side on my 1981 Blazer but do go on. They are a little tight underneath my brake booster. At first I thought I would have to cut it some.
wildmanaaron is offline   Reply With Quote
Old 07-10-2007, 03:15 PM   #2
knightlife
Dark Heart Motorsports
knightlife's Avatar
Re: Ls-1 Swap Question-for Those Who Have Done One
just run a straight cable like srub did...I think it was srub...*shrugs* that way its as long as YOU need...
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 07-10-2007, 05:26 PM   #3
wildmanaaron
Who is Shrubs? I would like to get one that is like the original one that was used in the 73-87 Trucks so the accelerator cable hole in the firewall will be the same.
Old 07-10-2007, 05:59 PM   #4
longhorn71
longhorn71's Avatar
did the ls1 ac compesser fit with out having to re-locate it?
longhorn71 is offline   Reply With Quote
Old 07-10-2007, 07:26 PM   #5
knightlife
knightlife's Avatar
what he did was pick up some small cable about the same size as that which is already used...and just trimmed it to the length he needed... just use the old hookup from in the cab, and the plastic runner and you should be aight. then run it to the length you need (after installin the damn ls1...) and viola! you are pimpin
Old 07-10-2007, 08:35 PM   #6
bagged74
its just $$$$$
bagged74's Avatar
Lokar
bagged74 is offline   Reply With Quote
Old 07-10-2007, 11:35 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by bagged74 View Post
Lokar
That's what we used on my Blazer..
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-11-2007, 12:11 AM   #8
kevinr1970
Seems like you have been making some moves on the Blazer with only slight little hints dropped here and there... are you going to drop a massive "heres what I have been up to" thread in the near future?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 07-11-2007, 12:14 AM   #9
bagged74
its just $$$$$
bagged74's Avatar
Ken is a sneeky little devil
Old 07-11-2007, 12:23 AM   #10
liljon285
That Guy
liljon285's Avatar
I SOOOO wanna do that but dont have the money!
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer!
liljon285 is offline   Reply With Quote
Old 07-12-2007, 04:42 PM   #11
wildmanaaron
I took the A/C Compressor off because I have a "topless Blazer" that I don't plan on putting the top back onto. I swear it would fit though. There is tons of room between the frame rails. I am trying to get my fuel lines, transmission lines, and PS lines done now. Got my other Corvette fuel rail cover today to really make the swap look a little better.
Old 07-12-2007, 05:32 PM   #12
bagged74
its just $$$$$
bagged74's Avatar
so where are the pics?
Old 07-13-2007, 10:33 AM   #13
wildmanaaron
I know I have to post some on here. I just hate having to upload them somewhere else and then linking them to the site I use to host em.
I still think I am going to try and use a 99-Up Chevy Truck accelerator cable. Making a cable just sounds like a pain. I want the engine compartment to look as stock as possible.
Old 07-13-2007, 10:49 AM   #14
bagged74
its just $$$$$
bagged74's Avatar
You can attach them directly without hosting them somewhere else.
By far the easiest will be the lokar cable, cut to length and install should take less than an hour. plus they work and look sweet. THey come in black too if you are wanting it to blend in.
Old 07-13-2007, 12:41 PM   #15
68Stepbed
68Stepbed's Avatar
I'll also say Lokar. They make high quality products that are simple to install and look simple(they don't look cluttered).
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-13-2007, 11:00 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
I normally dont talk about it because it hasn't seen progress in a long time. The LS1 conversion was done a few years ago.
It should see some in the next few weeks and I will proudly display some pics.
Sorry for the thread jack...
Articles-
"Refining Sierra"
Old 07-14-2007, 11:00 AM   #17
piecesparts
Parts and more parts
piecesparts's Avatar
Agree LOKAR Good people---they will build what you need, if they don't have it. They built me a cruise control cable for my 91 TPI mod.
piecesparts is offline   Reply With Quote
Old 07-17-2007, 01:54 PM   #18
wildmanaaron
I can't get the site to load when I am at home. Has anyone else had this problem? It says the site is unavailable. I have tried several times now and can only log in at work.
Old 07-17-2007, 10:41 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Try dumping your cookies at home. This site has been reloaded a few times recently with some updates. If your browsing with MIE go to "tools" then "internet options" then click "delete cookies" and "delete files" Close that browser and reboot. That should take care of your problems.
If your file size is too large load them one at a time, or resize them before loading...
Articles-
"Refining Sierra"
Old 07-22-2007, 07:43 PM   #20
midwestcar
midwestcar's Avatar
lokar is the easiest way to do it
midwestcar is offline   Reply With Quote
