07-10-2007, 10:18 AM | #1 |
Active Member
700R4/np205 setup
Trying to get all info on putting a np205 behind a 700r4 I have read that you have to either change output shaft on tran or shorten it by 3/4". Use an adapter for th350 then good to go Anyone have more info? Thanks in advance.........Rick
07-10-2007, 12:43 PM | #2 |
Active Member
Re: 700R4/np205 setup
Got the adapter, obviously the above information was wrong. Anyone have the right scoop on this change? Thanks.........Rick
07-10-2007, 04:44 PM | #3 |
Active Member
Looks like I'll have to go with advance adapters unless someone comes up with better idea.........thanks......Rick
07-10-2007, 05:07 PM | #4 |
try the search on this site. this topic has been coming up every few weeks here lately. good luck. -steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
07-10-2007, 07:46 PM | #5 |
You can use the stock TH350 adapter, but you have to run a shortened output shaft in the tranny or build a spacer to take up the difference.
Mike
Mike Redpath |
07-10-2007, 08:15 PM | #6 |
Active Member
Thanks for info. Advance adapter has shortened out put shaft. I have th350 adapter but the np 205 was out of 4-speed. AA also has coupler to go to 10 spline goes inside th350 adapter. That setup is $276. It's $172.50 just for the output shaft. I don't think I could find input for 205 27 spline for less than that. Plus I would have to swap out. Let you know. By the way my truck is '70 K10 shortbed fleetside.Fac AC PS 6cyl ........Rick
07-11-2007, 09:17 AM | #7 |
If you go all gm parts you'll need an adapter from a TH350, the input shaft for a np205 that was set-up for a TH350 and the short trany out put shaft from AA. or find a complete NP205 that is from a TH350 set-up. ( 27 spline )
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
07-11-2007, 11:51 AM | #8 |
I have a 27 spline input i just pulled from my 205 for a 32 spline if you need it.
Mike
Mike Redpath |
