07-10-2007, 01:14 PM | #1 |
Commander Taco Bello
Valve Sticking Open
So after driving my truck for the last two weeks, i noticed the other day that my right rear bag was filling to the PSI of the tank. after some thought, i realized that the fill valve was sticking open. I can get it to close if i hit the open switch a couple times, but it's a problem i'd like to fix.
Does anyone have any solutions that don't involve taking the valve out and replacing it? I'm not running a water trap, and I do not have exhaust reducers or muffers on my dump valves. I plan to get something on the dump valves to prevent crud from getting into them soon. |
07-10-2007, 03:24 PM | #2 |
Re: Valve Sticking Open
I would take the valve apart and make sure there is no sand in it. I have had valves do that in the pass.
07-10-2007, 09:30 PM | #3 |
Take the valve apart and put some pnumatic oil on maine parts,also think about running some water separators.
07-10-2007, 09:38 PM | #4 |
i highly doubt water is causing this problem ... these valves are designed for pneumatic systems and by the nature of compressed air they are going to have moisture in them.
Sounds like you have something lodged in the spool ... if you used Teflon tape on your fittings, then I would be almost willing to be that it's a piece of that. Good luck and let us know what ya find out. P.S. These valves are not complicated at all to disassemble ... pull her out and tear her apart ... the curiosity is KILLING me! |
07-11-2007, 12:32 PM | #5 |
Mine did the same thing. When my truck was parked, the right rear bag would slowly fill to equalize the tank pressure.
Take it apart and make sure it's clean. Might need to replace the valve.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
07-11-2007, 06:21 PM | #6 |
the valves are completely rebuildable, so as long as the case or the solinoid isnt broke then its fine. Clean it out really well, if that does work then buy the $3 rebuild kit and rebuilt it with a new diaphram and such.
07-12-2007, 09:56 AM | #7 |
Yeah, i think taking it apart is my only option. hopefully i can take the valve apart and clean it w/o removing it from the assembly i put together for each bag. I got lucky and had no leaks the first time, and don't want to create one now.
Here's a pic of the assembly i'm talkin about. |
07-12-2007, 03:11 PM | #8 |
not to hijack.. but what gauge wire is recommended to run to the valves, my eai switch box has some tiny wires running into a connecting block (cat 5 size) and im curious if i can run similarly small wires.. thanks, hope you figure out whats up w/the valve
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
07-16-2007, 01:35 PM | #9 |
to the valves i'm pretty sure 16 gauge is suggested. the compressor needs larger wire though. 10 is what i used.
07-16-2007, 01:54 PM | #10 |
What valves are you running?
Mike 1972 LT1/4l60e Short Bed ART Front and Rear Strong Arms http://www.67-72chevytrucks.com/vboa...50#post2151750 |
07-16-2007, 06:03 PM | #11 |
On the fast track to nowhere..
Maybe Parkers?
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
07-16-2007, 06:49 PM | #12 |
they look like SMC's to me ...
07-17-2007, 02:20 PM | #13 |
Smc 3/8"
