![]() Join Date: Aug 2005
Need Pics of...
60-66 Burb/Panel liftgate hinges. Someone pointed out that they are internal (unlike 67-72) and I'm wondering if I can adapt them or a similar design to my 69 Tahoe. Thanks
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Need Pics of...
I can get you some pics tomorrow if someone else doesn't before then.....The Burb is at the shop and I'm home now
60-66 Nut
Re: Need Pics of...
In your post Frizzle Fry you said the lift gate, but what I call the hatch is where the hidden hinges are at. So I took some pics of the hatch hinges. If you were wanting pics of the lift gate hinges I can get those for you....although they aren't hidden.
Re: Need Pics of...
That's what I was looking for! Thanks
60-66 Nut
Re: Need Pics of...
I might have an extra pair if you decide you want to try to make them work for your Tahoe. Those hinges often times get seized up from rust and such, and also where they bolt to the hatch is a weak area that will crack out due to the stiff hinges.PM me if you like.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 07-12-2007 at 12:24 AM. |
