07-10-2007, 09:43 PM | #1 |
Flat Black, & Chrome!
Got er back!
I got my truck back from the body & paint shop, with the base coat on it, my plan is to block the base coat myself right before its i have enough to get it painted with the final coat, and then when I get the money in a few months bring it back to get the final hugger orange sprayed on!
For now I'm just gunna drive like it is, well actually tomorrow I gotta take the front end apart and I'm going to cut the springs a little while I'm in there, and I'm painting the rallies gloss RED! |
07-10-2007, 11:55 PM | #2 |
Re: Got er back!
Theres still a few rough spots in this coat, I was wonderin should I wet sand it out or dry sand? what grit should I use?
07-11-2007, 03:07 PM | #3 |
Cruzzzn' Vet
Re: Got er back!
There's something about a primered truck that just sets it apart from the rest
i'd leave it primed and throw the beauty rings and cap on the Ralleys,RED rims and Black primer |
07-11-2007, 04:04 PM | #4 |
THE VILLIAGE IDIOT
Re: Got er back!
looks good..leave it in primer,,red rims,,,
honestly honey,,i have no idea how that truck got here. |
07-11-2007, 04:21 PM | #5 |
Re: Got er back!
Yeah guys I gotta say I dig the primer too! I'm probably going to roll it in primer and red rallies for a few months. I am in the process of removing the springs, I'd I'm trying to figure out how to cut them, anyone know?
07-11-2007, 04:45 PM | #6 |
Re: Got er back!
If there are a few areas that your not happy with wet sand 320 grit and repaint.
esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
07-11-2007, 04:47 PM | #7 |
Re: Got er back!
Right on thanks for the responce!
07-11-2007, 04:48 PM | #8 |
Re: Got er back!
I managed to figure out a way to cut the coil, but I'm trying to figure out how much is considered one whole coil, because the bottom coil is almost all flat, where would I cut to remove one complete coil?
07-11-2007, 07:00 PM | #9 |
Dark Heart Motorsports
Re: Got er back!
it looks so sexxy...I'd hit it...
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
07-11-2007, 07:31 PM | #10 |
Re: Got er back!
The very end of the spring is your guide for where to cut the 'next' coil above it.
07-11-2007, 07:48 PM | #11 |
Real Projects never die
Re: Got er back!
inspiration....ive bought three trucks sofar, two are parts trucks for my swb, haha
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
07-11-2007, 08:30 PM | #12 |
Re: Got er back!
Thanks, do I need to worry about "flattening out" the last coil like like the original bottom coil was?
07-11-2007, 08:32 PM | #13 |
Re: Got er back!
I'm glad you guys like it, I managed to get a few more things done today after battling the rubbing issues on the lower control arm. I put the front bumper on and the mirrors as well.
07-11-2007, 08:37 PM | #14 |
Re: Got er back!
07-11-2007, 11:06 PM | #15 |
Re: Got er back!
well I measured the front passenger height and after cutting 1 coil I got no drop at all!? I havent cut the drivers side yet, how many should I cut now?
07-11-2007, 11:44 PM | #16 |
Happy to be here
Re: Got er back!
DO NOT cut it again. Make sure it's seated in the A-arm correctly. Do the other side and roll it out. It will settle down....
07-11-2007, 11:45 PM | #17 |
Happy to be here
Re: Got er back!
I wouldn't sand the primer either. Unless you sand the entire truck all one direction, you will have a different texture in the area you sand.
07-11-2007, 11:47 PM | #18 |
HALF ASSER
Re: Got er back!
THIS IS A 1 1/2 COIL.WHEN CUT THE OTHER SIDE YOU WILL NOTICE IT!NO SPINDLES WITH A 275-60-15.
07-11-2007, 11:49 PM | #19 |
Re: Got er back!
Alright thanks I'll get to the other side tomorrow and I will hold off o sanding!
07-12-2007, 12:01 AM | #20 |
Re: Got er back!
Do you have any rubbing issues? I'm takin my wheels off a few times a day to grind a little more off the lca's
07-12-2007, 09:57 PM | #21 |
Re: Got er back!
day 3, truck is up on jack stands, I'm replacing the ball joints! tops are done, but I can not find a place to rent me the tool to remove the lower ball joints!
07-13-2007, 07:29 PM | #22 |
Re: Got er back!
I got the new ball joints in and 1 coil cut on both sides, front is finally done!
07-13-2007, 07:32 PM | #23 |
It followed me home?
Re: Got er back!
looks good, how much did it drop cutting off a coil?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
07-13-2007, 07:46 PM | #24 |
Re: Got er back!
measuring says only 1/2" but I'm pretty sure its a little more.
07-13-2007, 08:35 PM | #25 |
Re: Got er back!
looks good.it's got some stance.
" Never look up a dead dogs butt." |
