Old 07-10-2007, 11:14 PM   #1
gene_champ
what engine to replace 216 in 1949 pickup
i am starting to restore a 1949 3100 pickup. i want to use it for daily use. i will keep the 216 for future use, in case i want to have it original. i don't know what engines are commonly used for replacements. for now i just want a engine more suitable for daily use at normal highway speeds. what would be a good choice for a good dependable engine that is not too much of a gas hog??
1949 chevy 3100, 5 window
1992 chevy k1500, extended cab, short box 5.7l
1996 chevy k1500, extended cab, long box 5.7l
2001 chevy impala ls 3.8l
1965 honda s90
gene_champ is offline   Reply With Quote
Old 07-10-2007, 11:31 PM   #2
cajundragger
Re: what engine to replace 216 in 1949 pickup
if you keep it straight 6 I'd go with a 235....they are everywhere.
cajundragger is offline   Reply With Quote
Old 07-11-2007, 12:12 AM   #3
Daniel U
Daniel U's Avatar
The straight 6 is ok if you update your rear gears and trans to a 5 speed. I wanted a little more get up and dropped a TPI 5.7(350) with a 700R4 and 10 bolt rear posi with 4 wheel disc to slow it down properly. If you just want a cruiser, keep it simple and affordble. Someone on here from Florida did a 235 with a T-5 and a 10 bolt. They even kept the original stick. Do some thinking and some research. Keep in mind what your budget is and your capabiities as a mechanic. Good luck and keep us posted. BTW Welcome to the board.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 07-11-2007, 02:39 PM   #4
ADBob
I will be putting a 261 inline 6 (bit harder to find than a 235) and a T-5 transmission in my 1950 3100. Just need to find a decent frame first.
Look at the forum and tech tips at http://www.stovebolt.com they have all the info you need on 235 and T-5 swaps.
Bob
ADBob is offline   Reply With Quote
Old 07-11-2007, 06:23 PM   #5
cajundragger
or inliners.org
