Old 07-11-2007, 01:34 AM   #1
my70chevyc10
my70chevyc10's Avatar
Trans swap help
I am going to do a trans swap from 3 ON THE TREE TO A turbo 350 and i want to know if i can still use the same drive shaft from the 3 speed?
my70chevyc10 is offline   Reply With Quote
Old 07-11-2007, 09:52 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Trans swap help
If you use a shorttail 350 Turbo(6"tail), you will be the proper lenght & spline for your swap. Best of luck, L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-11-2007, 04:00 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Trans swap help
Woah... the old man is still around... where you been crazy?
