Old 07-11-2007, 07:51 AM   #1
OLDCHEV4X4
OLDCHEV4X4's Avatar
205 problem
My 205 TC has a problem. This is in my race Blazer so it gets abused and it stays in 4 low all the time. Its a 205/th350 combo.
When i put it in reverse it wouln't move. When i put it in 1, 2, or 3 it moves. This happened in the middle of a race.
I figured it was the trans. No problem, one of my sponser's is a trans guy and he was there and said it was the reverse oneway clutch.
Ok so i get home, take it out, and give it to him. He calls me and says there is nothing wrong with the trans. He says check the slider and shifter fork in the TC.
So i open up the TC and don't see anything obvious. The upper shifter fork has .025 play between the side of the fork and the groove of the slider. The slider has some slop in it, but i dont think its too much.
Has any one else had this problem???
I wish i had tryed 4 hi before i took it out of the truck!
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 07-11-2007, 09:10 PM   #2
eedgell
It's the air up here
eedgell's Avatar
Re: 205 problem
If the transfer case is engaged, and will go forward, I have never heard of them not working in reverse. I dont think it is mechanically possible.. Is it.? Has to be in the transmission or its linkage.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 07-11-2007, 09:47 PM   #3
kwmech
Re: 205 problem
I would be looking at one of the diffs failing before a 205. They are pretty tough, I've seen just about 800HP going thru one without failure.
Thought: you didn't specify why the vehicle didn't move. Did the engine rev like in neutral or did it bind up?
Old 07-11-2007, 10:01 PM   #4
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: 205 problem
its not the tcase. it either work 100% or it doesnt.
trkklr77 is offline   Reply With Quote
Old 07-12-2007, 07:52 AM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: 205 problem
kwmech, it reved like it was in neutral. I checked trans fluid, looked for leaks. After this happend i drove 10 minutes back to the pits. I had all 3 foreward gears, but still no reverse.
My trans guy is real good. The jeep dealership brings him transmissions to fix because they cant. He's been building HP transmissions for 20 years. So when he says the trans is ok, I believe him.
I have a extra 205 TC that i'm going to throw in and see if that fix's it.
I forgot to mension that once i got back to the pits, it did back up but it was jerking back and forth and making noise. Then it wouldn't move back any more.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 07-13-2007, 07:10 PM   #6
b.sharp
b.sharp's Avatar
Re: 205 problem
I've had the same problem in an 80's blazer and it was the reverse clutches slipping. All forward gears worked for a few days and then 1st and overdrive went out because they are in the same clutch pac. I believe I would ask him about looking at the clutch disks to see if they're worn or have any appearance of hot spots. That's just my two cents worth. I have never seen a transfer case not work in reverse and work in forword and I grew up with a dad and uncle that did a hole lot of 4 wheelin through you name it they'ld put their trucks through it. Dad had a '79 with 6" lift and 3" body lift with 44 ground hogs and would go about anywhere. He's the one they called when they had a truck stuck in a deep hole of mud or water. Man would I love to have that truck today (except for putting gas in it!!!)
b.sharp is offline   Reply With Quote
Old 07-17-2007, 07:15 AM   #7
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: 205 problem
Update:
The Blazer is back together. It backs-up fine. No noise. This is with the same transfer case and the same transmission.
Looks like I'm racing at Line Mountain this weekend!
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 07-17-2007, 09:36 AM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: 205 problem
Pretty odd, hope the race goes well for you!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-17-2007, 10:09 AM   #9
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: 205 problem
Yes Yukon it is odd. Didn't find nothing wrong with the trans. (So he says. Mabey he did but he's too embarased to admit it.) I didn't find nothing wrong with the TC. Put it all back together and hope for the best. If it does break, hopefully i'm not 5 miles out on the track when it does.
Thanks for the "hope". I need all the help i can get!
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 07-23-2007, 08:55 AM   #10
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: 205 problem
Update:
Reverse worked fine all day. And so did the TC. Same everything. Its a mystery. I guess i " Got my mojo working".
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
