Old 07-11-2007, 11:47 AM   #1
ScottH
ScottH's Avatar
Need pic of a stock split rim
Can someone post a pic of a stock split rim? I need to determine if the wheels on my 67 are split or not. Need help identifying the lock ring.
Thanks!
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 07-11-2007, 12:28 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Need pic of a stock split rim
Here's a pic of the stock 16" split rim that was originally on my 69 K20.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-11-2007, 12:39 PM   #3
ScottH
ScottH's Avatar
Thanks Yukon Jack.....is the lock ring the gray part on the outer part of the rim?
Old 07-11-2007, 03:14 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Yep.
Old 07-12-2007, 03:59 AM   #5
rwgregory
Scott, on the photo from Yukon Jack look at the gray lock ring at the 11:00 position. You will see that it is cut,(or split). This allows the ring to be removed from the wheel. When the tire is inflated the air pressure will press this ring against the edge of the rim, thus creating a ridge or shoulder for the bead of the tire to press against. If the lock ring is not properly seated on the lip of the rim it can come loose and fly off with tremendous force.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 07-12-2007, 09:14 AM   #6
ScottH
ScottH's Avatar
Thanks to all. Looks like I do not have the split rims after all.
Scott
Old 07-12-2007, 02:42 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
to add to rwgregory's post... when the ring flys off, it'll kill anything in it's way. I've seen them fly off of the old duce & a half trucks in the army and land far enough that you wonder where the h*ll it came from.
