07-11-2007, 01:07 PM | #1 |
Sofa King. We, Todd, Ed.
Brake Proportioning Valve Question?
I know most serious 1st gen. 4x4 Blazer guys have converted to Hydro-boost, but I was wondering if any one has had any luck/experience with removing the proportioning valve or replacing it w/a universal adjustable valve?
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
07-11-2007, 03:09 PM | #2 |
Post Whore
Re: Brake Proportioning Valve Question?
I'm I correct to assume you are disk front/drum rear? My 69 K20 is drums all around and I did not add a prop valve when I swapped in the hydroboost. Works well for me but I'm sure if you are disks and drums you will need a prop valve. I think Burt4x4 has an aftermarket prop valve on his K5.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
07-11-2007, 03:17 PM | #3 | |
07-11-2007, 05:58 PM | #4 |
Nope I have the factory p-valve. I upgraded to the 1ton double diaphram booster/master combo, pictured above. Was a direct bolt in deal except I had to get new lines from the master to P-valve as the 1Ton setup plumbs opposite of the 1/2 ton setup. In-line tube sells the lines for like 25bucks. This setup DOUBLED my stopping power!! I can actuall lock up all 4 tires now! No way in H*** I could have done that with the 1/2 ton stuff. BUTT ~ now I have a D60 w/14FFdisk and I am only assuming my brakes will be the same as I have yet to bleed the new calipers/axels and test drive it but by Monday I will beable to tell you if this 1Tonsetup with factory P-valve works as good or not.... to be continued...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
07-11-2007, 06:07 PM | #5 |
What's the green thing behind your booster...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
07-11-2007, 06:25 PM | #6 |
[QUOTE=Burt4x4;2260011][IMG]http://www.norcalbigdawgs.net/Gallery/albums/albuo05/P1010005.jpg[/IMG]
"Nope I have the factory p-valve. I upgraded to the 1ton double diaphram booster/master combo, pictured above." Ah, great minds think alike. On the left is a stock 71 blazer set up. On the right is a 71 one ton pickup set up. Working in a parts store sure has its benefits. Good to know it worked for you.
07-11-2007, 06:32 PM | #7 | |
[QUOTE=johnnywagon;2260049]
Can you give me part numbers, prices, source for that one on the right? Thanks, Misled |
07-11-2007, 06:40 PM | #8 | |
[QUOTE=Misled;2260059]
OR just have your local parts store look up a vacuum booster/master cylinder combo for a 71 or 72 1-ton full size 4x4 pick-up. Like Burt said you will have to make new brake lines, also the booster mounting studs are a little wider on the on the one ton, but the firewall brackets can be "massaged" to work.
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon Last edited by johnnywagon; 07-11-2007 at 06:41 PM. |
