Old 07-11-2007, 08:49 PM   #1
pyro883
Grinding Noises
Yesterday I couldnt get the truck to fire up and run. I found out that the previous owner jerry rigged the hei distribtor up so I respliced all the wire and then I got it running. Now I went out to try to start it up it is making a grinding noise when i try to start the truck. I tightened up the battery terminals up, and it seems to still be grinding any ideas?
pyro883 is offline   Reply With Quote
Old 07-11-2007, 09:29 PM   #2
OlChev67
Ever heard of Beech Island??
OlChev67's Avatar
Re: Grinding Noises
can you tell where the noise is comin from?
see if the starter is tight.
are the clips on the dizzy cap tight?
OlChev67 is offline   Reply With Quote
Old 07-12-2007, 05:08 AM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Grinding Noises
find out where abouts its coming from but my guesses would be the starter, dizzy or even the gears if its a stick and not sitting fully in neutrel
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-12-2007, 06:05 AM   #4
Re: Grinding Noises
Cut back on the cafeinne?I`d check the starter.May need shimmed if it`s not loose.Could be a mismatch,too.Or,a damaged gear ring on flywheel/torqur plate.
Old 07-12-2007, 08:22 AM   #5
rlm316
rlm316's Avatar
Re: Grinding Noises
Make sure that the solonoid is de-energized after the truck starts.
rlm316 is offline   Reply With Quote
