Old 07-11-2007, 10:18 PM   #1
68c10owner
68c10owner's Avatar
47-55 weight?
What does a 3 window shortbed with a MII frontend weight? I`m guessing about 3500lbs? sound about right?
Anthony
68c10owner is offline   Reply With Quote
Old 07-11-2007, 10:28 PM   #2
cajundragger
Re: 47-55 weight?
something like that. It isnt much.
cajundragger is offline   Reply With Quote
Old 07-11-2007, 10:43 PM   #3
68c10owner
68c10owner's Avatar
Re: 47-55 weight?
The reason I ask is I`m still trying to buy this truck from this old man I know and I`m getting a great running 327 from another friend and I figured if the weight is close, it should run just as good in the old truck if I gear it the same. Thanks.
Anthony
Old 07-12-2007, 02:23 AM   #4
Daniel U
Daniel U's Avatar
Re: 47-55 weight?
What BHP is the 327? What are your plans for the pick up?
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 07-13-2007, 12:02 AM   #5
Deabt54
Deabt54's Avatar
Re: 47-55 weight?
Hey there, I've got a 55 1st. 5 window running a 283, with a 350 turbo and 12 bolt rearend. I had it weigted and it came to 3,220 lbs. If that any help to ya.
Deabt54 is offline   Reply With Quote
Old 07-14-2007, 07:04 PM   #6
solidaxel
solidaxel's Avatar
Re: 47-55 weight?
I would not have gussed that these trucks are that light, with all that real steel!!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-14-2007, 08:59 PM   #7
68c10owner
68c10owner's Avatar
Re: 47-55 weight?
I don`t know the hp rating of the motor but it would probably run high to mid 13`s in my buddys chevelle. My plans are pretty much just to drive it but I want to burn up some tires sometimes too,lol.
deabt54,yeah that does help alot. i plan to run a th350 and a 9" so the weights should be similar. Are you running the stock fronend or a MII set up?
Anthony
Old 07-14-2007, 11:55 PM   #8
Deabt54
Deabt54's Avatar
Re: 47-55 weight?
Its stock with 5 lugs and drums. Getting ready to put a 89 corvette suspension up front. Got the cross member from Progessive Automotive. Should be fun LOL!!!!!
Old 07-15-2007, 10:13 PM   #9
cajundragger
Re: 47-55 weight?
me and two other people picked up my frame with the cab on it and moved it no problem...its super light.
WIth my boxed frame its a bit heavier now but still light Im sure...
