Old 07-12-2007, 12:32 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
tube grill / hood latch interference
im about to purchase a custom tube grill and was wondering if the hood latch would be accessable through it. it looks like there isnt a place to get my hand in there. does anyone have experiance with these?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 07-12-2007, 07:59 AM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: tube grill / hood latch interference
well in my 86 it wouldnt be an issue cause you pull the hood cable in the cab the lift it again after the hood has poped up about 2 inches, That were my 2nd latch it.
Now if it and older model like the 70s i really doknow never had one but id think id go for the late 80s model hood opening mechanism. (fabrication time)
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 07-12-2007, 01:24 PM   #3
crm318
crm318's Avatar
i see alot of 70s trucks with the tube grill.
1972 Cheyenne
Old 07-12-2007, 01:40 PM   #4
CUBaseball
CUBaseball's Avatar
I can fit enough of my hand through my square tube grill to pop the first latch, but not the safety latch. Instead, I can raise the hood enough to depress the latch arm itself to release the latch. It's a little dificult to open, but I don't worry about other people getting in there.
CUBaseball is offline   Reply With Quote
Old 07-12-2007, 01:44 PM   #5
1933 Gasser
I made a release rod out of a lawn sprinkler handle I got at Home Depot. It has a D-shaped handle on one end and I threaded the other end to attach it to the latch. It is accessable from under the grille. I used a cable clamp to use as a guide and attached it to the grille support.
Once I get a front bumper, I'll probably have to change it to something else.
1933 Gasser is offline   Reply With Quote
