Old 07-12-2007, 07:28 PM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Question bed swapping question
I have a '71 C20 with a utility bed on it. I'm thinking about buyinga '74 C30 dually with a nicer, bigger utility bed. Will the bigger bed fit on my older truck? I'll swap out the rearend and suspension too.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 07-12-2007, 08:25 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: bed swapping question
Most of the utility beds I've looked at were a "Universal" fit.Meaning the bed could be mounted to almost any truck but you would have to build mounts from frame to bed.That said,the big thing to keep in mind is weight.If the 'new' bed is bigger it is probably heavier.Since you intend to swap the suspension it would probably work out.Just crawl around under both with a tape and pad to see if it will work.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
