Old 07-12-2007, 08:09 PM   #1
67 cst swb
67 cst swb's Avatar
I got a parts truck
its a 69 GMC with a factory 6 cyl, Powerglide, & suppost to be a posi rearend, even has powersteering.
Here's my question...?
what are the rear end gear possibilities? What are they most likely to be behind a 6 cyl with a powerglide?
It would be awesome to be a 3.73 posi. But, I just hoping to hear the possibilities. The glove box door says nothing about rearend.
I won't be getting it home until the July 21-22nd weekend.
I will be parting out this truck, so watch for it on the Parts Board...
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 07-12-2007, 08:46 PM   #2
lpaine
lpaine's Avatar
Re: I got a parts truck
It's probably lower gears-being that it has a 6-, but you'll never know until you take the diff cover off and count the gears. My '69 originally had a 6 & 4.57 gears, (apparently the 6 cylinder trucks usually had lower gears) let us know what you find.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 07-12-2007, 09:14 PM   #3
Probably a 3.73 unless the glove box sticker says other wise, but like was said no telling unless you can find the axle code or pull thecover.
Palf70Step is online now   Reply With Quote
Old 07-12-2007, 09:29 PM   #4
67 cst swb
67 cst swb's Avatar
Glove box said nothing of the rear axle... owner said it was a posi. Well, it's encouraging that it might be a 3.73, or even 4.11 would be great for my project.
Thanks guys...
My Trucks:
Old 07-12-2007, 10:01 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Bryan,
If you're not sure what ratio your rear axle is there is a code stamped into the axle tube (see pics) and you can go here and look it up in the "axle" section. You only need the first three letters at this site. If your truck originally came with a six cyl it probably would have had a lower geared rear end.
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
LockDoc (Leon)
Leon
Old 07-12-2007, 11:28 PM   #6
67 cst swb
67 cst swb's Avatar
I used to (still do somewhere) have an original GM book showing these rearend codes, just can't find it anywhere.
also, I only looked at the truck for 3 minutes. I'll find out more when I pick it up. I was just wondering the most likely ratio of a 6 cyl/P.Glide equipt truck, if the glovebox doesn't list anything. I'm assuming a 6 cyl/ PG only had 2 or 3 options... what is the most likely stock ratio...
Is it possible to be a 3.73 or 4.11 stock in that truck or are they more likely to be 2.73, 3.08 or something else.
So, when people say "lower geared" what does "Lower" mean? I've heard these terms for years, but don't know what it means numerically. Give me some examples of Lower. I'm assuming the opposite of lowered geared is higher geared... what are some gear ratio's that go along with these terms?
My Trucks:
Old 07-12-2007, 11:32 PM   #7
sdkid
Lower gears equal higher numbers....4:11, 3:73 etc. In my mind the 3:73 is the starting point for lower gears. I don't know how low they went in 1/2 ton. I'm going to assume thia is a 1/2 ton your getting.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 07-12-2007, 11:44 PM   #8
67 cst swb
67 cst swb's Avatar
yes, 1/2ton GMC 2wd...
So, "Lower gears" are higher numerically??? "Higher gears" are lower numerically.
So, if 3.73's are the starting point, 4.11's are lower and 5.13's are very low...? am I following you...?
How did they come up with such terms...
I would think lower would refer to numerically lower, what does the "lower" refer to. Lower top speed (hehehehe)...
sdkid... congrats on the 1000th post
My Trucks:
Old 07-13-2007, 12:50 AM   #9
sdkid
Don't know how they came up with it. 3:73 is just my opinion of the starting point. Someone else may say different. I believe that is where the posi carriers change from series 3 to series 4 though. Which is why I tend to think the way I do. And yes, you're following me.
Thanks for the nod, look like you recently passed that milepost your self.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
Old 07-13-2007, 08:27 AM   #10
LockDoc
LockDoc's Avatar
In this chart the first one is the highest and the last one is the lowest.
I don't know how the high and low were derived unless it is the number of teeth on the pinion in relation to the ring gear. The 2.56 has 16 teeth on the pinion and 41 teeth on the ring gear and the 4.10 has 10 teeth on the pinion and 41 teeth on ring gear, so the 4.10 has a "lower" number of teeth on the pinion in relation to the ring gear. Don't really know though....
Ratio 2.56:1 - Tooth Combination 41-16
Ratio 2.73:1 - Tooth Combination 41-15
Ratio 3.07:1 - Tooth Combination 43-14
Ratio 3.08:1 - Tooth Combination 40-13
Ratio 3.08:1 - Tooth Combination 37-12
Ratio 3.31:1 - Tooth Combination 43-13
Ratio 3.36:1 - Tooth Combination 37-11
Ratio 3.42:1 - Tooth Combination 41-12
Ratio 3.55:1 - Tooth Combination 39-11
Ratio 3.73:1 - Tooth Combination 41-11
Ratio 4.10:1 - Tooth Combination 41-10
Ratio 4.11:1 - Tooth Combination 37-9
LockDoc
Leon
Old 07-13-2007, 12:48 PM   #11
67 cst swb
67 cst swb's Avatar
My boss just answered me that higher meant higher speed, and lower meant lower speed... I'm guessing in relation to top speed
My Trucks:
Old 07-13-2007, 12:53 PM   #12
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
the higher the number,,the slower yoru going on the high way..being a 6 truck,,its gonna be geared low,,3:73 or might even be 4:56 isnt it.. depends on weather a guy form the city bought it,,or a farmer,,most of the ol famr trucks were geared really low...but man even with a 6,,they could crawl up out of ahole with a load...
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 07-13-2007, 02:49 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if I am reading my book right, and they do word things funny, it'll be a 3.73 unless the engine was a 350 (which it wasn't) and it would be a 3.07. The powerglide was not avalible with the 396. (another moot point)
So, if there is no option listed for gearing, (same with posi, not listed, not equipped) and assuming left original, then it'll be a 3.73 open diff.
Old 07-13-2007, 06:45 PM   #14
67 cst swb
67 cst swb's Avatar
Longhorn Man... Thank You... Just what I was looking for. Thank You very much everybody for responding...
My Trucks:
