Old 07-12-2007, 09:43 PM   #1
otsenre
otsenre's Avatar
lift kits
The PO of a 70 shortbed 4x4 I recently purchased is telling me the lift kit on it is original. I didnt think chevy made any original lifts on these pickups. Anybody know whether they did or not? Thanks
otsenre is offline   Reply With Quote
Old 07-12-2007, 10:03 PM   #2
1969k10stepside
Re: lift kits
No,no stock lifts that I have ever seen.
1969k10stepside is offline   Reply With Quote
Old 07-14-2007, 07:55 AM   #3
va_tlc
va_tlc's Avatar
Re: lift kits
dustin... dont some come factory with blocks in the rear? mine had em. they looked stock enuff.
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 07-15-2007, 03:53 AM   #4
Wreckless_71
Wreckless_71's Avatar
Re: lift kits
I'm pretty sure Dustin's right Chevy didn't make any stock lifts for these pickups.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 07-15-2007, 11:15 AM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: lift kits
My 69 K20 had very short blocks in the rear and sure looked like I was the first to remove those u-bolts.
Wanna hear something odd, I bought a junker 78 K20 to put it's axles under my K5. This thing was awfully stock and I couldn't believe it when I pulled the front axle from the 78 and there were lift blocks under the springs. If my memory serves me correctly they were about 1" tall. The were not attached to the springs, just sitting there like a normal rear block. I can't say they were there from the factory but everything under there looked about rusted the same.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-15-2007, 02:06 PM   #6
jerry moss
Born Psycho
jerry moss's Avatar
Re: lift kits
i had a 70 3/4 ton 4x4 several years back with short blocks in the rear that appeared original. they had a GM part number cast into them and according to my big green factory parts book the 3/4 ton 4x4s with HD springs in the rear had the little blocks. if i remember correctly, they were about 3/4" tall. as for a "factory" lift kit---never heard of anything.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 07-25-2007, 11:39 PM   #7
customcamper72
Re: lift kits
I parted out a 69 4x4 and it had small lift blocks in the rear with G.M. part #,s on them. my 72 didn't have any blocks but the front spring hangers for the rear springs were different between the two trucks, 72 spring hangers hung down farther from the frame rail than the 69 had.
customcamper72 is offline   Reply With Quote
Old 07-26-2007, 04:47 AM   #8
Re: lift kits
My`72 GMC has those little blocks in the rear and air shocks.No factory lift kits."Lift kits" didn`t come around until after these truck weren`t being made anymore.And,I`ve never seen anything GM made considered to be lifted over stock from the factory other than the ZR2s.
