Old 07-13-2007, 02:02 PM   #1
jfrank133
AUSTIN TX
jfrank133's Avatar
Unhappy Question on Installing a Power steering Pump
I installed a power steering pump on my 87 chevy truck. Ever since I installed it, the pressure hose keeps linking the fluid, I have taken off several times, realign it and even used a sealant for when i tighten the line. Is there any special thing that i need to do to prevent it from leaking. Please help.
jfrank133 is offline   Reply With Quote
Old 07-13-2007, 02:21 PM   #2
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: Question on Installing a Power stearing Pump
what power steering did you use? The '70s ones require a double-flare pressure hose end, while the '80s ones use a slip-on and o-ring seal. If you mismatched the pump and the hose they will leak. Actually, now that I think of it, I don't think you can use '70s pump with '80s hose, you can however lose or forged to install the o-ring that seals the hose to the pump...
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 07-13-2007, 05:29 PM   #3
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Newer pumps are metric if I remember....but you can remove the fitting from the pump and install it into the other to match the hose.....
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 07-14-2007, 06:29 AM   #4
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Re: Question on Installing a Power steering Pump
OH GREAT......... So how can you tell what year your pump was made? Im doing the same thing installing power steering on my ride. Only I have a L6 just got the brackets and I did get this pump (used) and the dude I got it from said late 70's early 80's pump..
Hmmmm,,?
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 07-14-2007, 01:13 PM   #5
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
well the one that we put into my 84 leaks from around the extra plug that srews in the back of it..but i got to pull the pump to get to it.. mine more or less sprays..but it has slowed way down when i bought some new power steeering fluid with a sealer conditioner in it... whne i pull the motor, i will fix it...im not gonna spend 4 hours or more tryitng to get it o out again,,just to pull the motor...the new pump leaked worse than the old one...
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 07-14-2007, 05:06 PM   #6
Ivan D.
Ivan D.'s Avatar
Hmmmm,,?
Have you ever noticed how double-flared brake line fittings look where the brake line attaches and seals to them? Well, them that's what you're looking for - look down the high-pressure port of the pump, if you see something that looks like a huge double-flare brake line fitting then you have a '70s pump. The '80s pumps look like the A/C radiator ports, they have a flat face and line actually slides in them and there's an o-ring that seals the step formed on the line to the fitting's face, then the nut just keeps everything pressed together tightly. Really tho, it ain't that big of a problem:
- if you have an '80s truck and a 70's pump then cut off the pump side of the pressure line and double flare, reuse the pump's original nut
- if you have a '70s truck with a an '80s pump then cut the steering box end of the pressure line and double-flare that, reuse steering box's original nut
No matter which situation you have you should always use an '80s pressure line, as its o-ringed end can be made into double-flared ends, but there ain't no way to make a double-flared end of a '70s pressure line into an o-ringed end for an '80s system component. In my truck I run a hydro-boost off an '80s 1-ton diesel, for that I had to cut and double-flare one end of both the line from the pump to the booster and the line from the booster to the steering box, worked well and I have no noticeable leaks.
