09-21-2002, 02:37 AM | #1 |
Location: Bondurant, IA but in Worcester, MA for school
Put my new master cylinder in!!! But got a Question
I put my new master cylinder in my truck tonight. I bled the master cylinder when it was on the truck then connected the break lines. Tested the breaks and they worked fine. I did not bleed the breaks at each break drum. I drove the truck for like 2 hours tonight and worked the breaks really hard and they worked perfectly. My truck stops on a dime now. What my question is is that do I still need to bleed the breaks? Please let me know. Thanks
HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
09-21-2002, 02:48 AM | #2 |
Progress = 0%
I don't think you'd HAVE to bleed them, but if it were me, I would, just to make sure there is no air in the lines. Just me $0.02.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
09-21-2002, 02:52 AM | #3 |
Same as above. I would just to be sure. Who knows, maybe your brakes will be even better after you bleed them individually.
09-21-2002, 02:57 AM | #4 |
Ok so maybe I should...Whats the order of the wheels that I should bleed? Which ones should I bleed first? Thanks
HotRod
09-21-2002, 03:51 AM | #5 |
Jostrans68
Iwould bleed two reasons make sure there is no air 2 get the old fluid out. My .02 Jack
[CGTW Member former 67-72 now with a 96 silverado |
09-21-2002, 04:38 AM | #6 |
Any time you open the hydraulic system it should be purged of air. You could be just riding on well-balanced front brakes.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
09-21-2002, 06:08 AM | #7 |
Just Another Crazy Canuck
start at the wheel farthest away from the master(right rear) then work your way around and do the LF last
1985 454/465/205, 38.5x11-16BOGGERS soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI |
09-21-2002, 10:23 AM | #8 |
Too many projects
You should always bleed the brakes after breaking the lines. Burlinator has it right, start with the farthest and work your way to the Master cylinder, RR, LR, RF, LF.
09-21-2002, 10:31 AM | #9 |
now thats a true COON DOG
Yes, Burlinator has it right! You also might want to think about bleeding out the old break fluid! You never know just how old the "old" break fluid is in there and when that stuff starts to get old it will gum up your wheel cyclinders! Whice also means your brakes will start acting very strange, if that was to happen!
current project 67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!) 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well... 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!) 67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!) |
09-21-2002, 12:40 PM | #10 |
CCRider
I have worked as a mechanic for more years than I want to admit. When I worked in a forklift shop it was nothing to change out 6 or 7 master cylinders in one day. I have never had to bleed the brakes for changing one. Air wants to rise up in fluid, and what little air that is in the lines will burp up thru the master cylinder. If you leave the top off you can see it. If your pedal is rock hard I would not worry about it, unless you want to get the old fluid out.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
