I am installing the flaming river column made for our trucks.
Do you grind the "nipple or notch" from the factory mount or do you cut a hole in the column for the notch to fit into similar to the facory column? Thanks for your replies, Progress is slowly moving with my chevy project, but that is life, I guess.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
its all about the +6 inches
Re: Installation question for the flaming river column FR-2007.
got photos?
Where is the notch at? |
The notch or nipple is on the top side of the column where the column slides into the mount. I don't have any pictures, sorry. The stock column has a square hole cut in it for the nipple to fit into.
back to top for Saturday
Bill - does the FR column have a hole or a notch? I would think you would want to be as close to stock as possible. I would think the purpose is to keep the column from sliding forward or backward and from twisting left or right (say when at full turn when parking).
It does have a purpose and should be maintained - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Nothings as cool as my 72
I don't have a flaming river column but i do have an ididit column and i had the same problem. What bob said makes sense but it is to late for me now as i grinded of the little peace sticking out.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. ![]() |
![]() Join Date: Feb 2007
I have a 30 inch FR tilt column and did not run into said such critter??
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#8 | |
Thanks for everyone's replies.
Bill - am I mistaken or would this take just a hole drilled in the jacket? Without measuring I would think a 5/16th or 3/8s hole would do the job.
#10 | |
Once I drill that bad boy it is mine for keeps, you know what I mean? ![]() Thanks for your assistance.
Proud owner of a 55.1 AD
![]() Join Date: Oct 2006
I put in a FR-2003 column and was told to get the column set in place then tighten the mounting bracket and the nipple will make a dent in the column and prevent the column from moving back and fourth. So far I have noticed any problems, but the truck restoration is not finished yet.
Hope this Helps..... |
