07-13-2007, 07:31 PM | #1 |
kpcomponents notch..........
just got done buying a kpcomponents notch online and I already cant wait for it to get here. how is the quality of their products? and how well do they fit?
07-13-2007, 07:45 PM | #2 |
Insert Title Here
Re: kpcomponents notch..........
Ive never dealt with them.. but I havent heard any complaints
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
07-13-2007, 11:02 PM | #3 |
AttentionDeficitDisorder
top quality parts...you wont be disappointed.
07-16-2007, 08:34 PM | #4 |
True Addiction
Project 67, the quality of the notch is excellent. make sure and measure twice before you turn the welder on. I believe the best way is to get your sides tacked on, then top, then cut out the original frame, so that you can snug the bottom in. Good Luck.
07-16-2007, 08:42 PM | #5 |
Outlandish Trends - FL
I had good luck with mine:
-Bret 67 short-fleet sold! |
07-16-2007, 09:24 PM | #6 |
True Addiction
Looks good 67 Fleet, are you still running the stock trailing arms or something else. I'm running the same notch, bags and mounts as you are. However I decided to switch to a parallel 4-link and a narrowed ford 9". Let me know if you have any tips for this set-up.
07-16-2007, 10:25 PM | #7 |
I'm still running the stock arms out back. I think you'll be happy with a 4-link. It'll ride nice! Whose did you go with? KP or SD?
07-17-2007, 02:35 AM | #8 |
Junior Member
just a question i got a 68 C10 lwb fleetside coil rear end and was wondering what size of C-Notch, tire size to lay frame on the ground. ive seen 6", 8".
07-17-2007, 05:18 PM | #9 |
A guy with a truck
Tire size will determine notch height.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-18-2007, 12:26 PM | #10 |
That system looks very familair to the one I did on the black truck shown above. That KP Notch and Under The Bed mounts look sweet. Next would be a KP Bolt-On 4 Link for the 67-72 trucks if you decide to ditch the factory arms. Keep up the good work.
- Clint - Last edited by Kontrol Phreaks; 07-18-2007 at 12:26 PM. |
07-18-2007, 05:40 PM | #11 |
A guy with a truck
So, it's available?
07-18-2007, 06:07 PM | #12 |
True that.
Depending on what size wheel and tire combo you choose to run will determine how high you set the notch when it's welded in. Best thing to do is take all your measurement to figure out your ride heigth and drop height before you weld it in. Good Luck with the truck.
- Clint - |
07-26-2007, 02:45 PM | #13 |
Clint, I sent you a PM about a KP watts link. I need to know if it's available for 12-bolt GM rear end. I didn't see it listed on the site.
