Old 07-14-2007, 10:47 AM   #1
bighead
Front Axle ?
Another question for you fellers. What years front axles will fit the 72 K10 I just bought. I think it's a Dana 44 in there now. Do the 73-87's also bolt up or just the 67-72's? Thanks again, big
bighead is offline   Reply With Quote
Old 07-14-2007, 12:41 PM   #2
CrashEd
72 chevy
CrashEd's Avatar
Re: Front Axle ?
The 73-86 will work. If you get a 10 bolt make sure to get all the ubolts and spring plate there a different size but will bolt right in with them.
Ed
CrashEd is offline   Reply With Quote
Old 07-14-2007, 03:30 PM   #3
msgross
msgross's Avatar
Re: Front Axle ?
sure do.... Here is a little write up I did on the differences between the two.
http://67-72chevytrucks.com/vboard/s...d.php?t=240456
Cheapest route is to find a junked K-10 and pull the axle, brakes, steering (arm, drag link, box, pump if you need them all), spring plates and if you're lucky (or patient) then you can find the same gear ratio as the rear. Click on my build thread and you'll see my corp10 from an 82 now sitting under my 68.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
