Old 07-14-2007, 03:24 PM   #1
cell
Active Member
cell's Avatar
I made a brake drum puller
I decided to make a brake drum puller because I got tired of having to beat the crap out of my brake drums to get them loose.
see all the photos here:
http://cell.dreamhosters.com/photos/brake-drum-puller/
start with a 3 jaw puller from harbor freight:
then weld some extensions onto the arms:
cut to length, drill holes, and finish the edges:
viola:
cell is offline   Reply With Quote
Old 07-14-2007, 03:39 PM   #2
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: I made a brake drum puller
great idea i coulda used that on my 49
bad6772 is offline   Reply With Quote
Old 07-14-2007, 08:09 PM   #3
Sequoyah
so easy a caveman can do it...
Sequoyah's Avatar
very innovative! I just used a pry bar and eased it out around the drum...not putting too much pressure in just one area. It worked eventually, but prolly not as good as that.
Sequoyah is offline   Reply With Quote
Old 07-14-2007, 08:14 PM   #4
SkylineNXS
SkylineNXS's Avatar
I like that, a lot! I was trying to make a crappy one while i was getting mine off, but it never worked. Wish i had a welder to do that. How would u use it on the front drums is my question? Can u just pop off the cover for the spindle adn then put the little part of the puller right on the end of that bolt? That is an awesome job, nice....
Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 07-16-2007, 01:19 PM   #5
cell
Active Member
cell's Avatar
SkylineNXS: well, I didn't realize this at first, but it turns out the front rotors are riveted to the brake drums, so you have to take apart the bearing assembly in order to take the front brake drums off. I wound up grinding out the rivets so I could replace the brake drums and I'll be posting pictures of that in a few days when I finish my brake overhaul.
But yeah, the front spindles do have a divot right in the center, so the puller should work there as well (actually, I may not have made the arms long enough -- I might not be able to back the puller out far enough to fit onto the spindle. I'll have to try it out tonight).
Old 07-16-2007, 02:04 PM   #6
shaneschevys
Its always something!
shaneschevys's Avatar
Nice work!
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
