Old 07-14-2007, 06:34 PM   #1
john64
Can anyone decode my VIN please
Hello from Scotland, just bought a GMC long wheelbase truck ex North Dakota farm truck. It has coils on the front and leaves on the back 327 with 4 speed. It has small back window and 4 headlights. The plate on the door says
GMC Truck
GVW 5000
CE1590D PC1240A
John
john64 is offline   Reply With Quote
Old 07-14-2007, 06:51 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Can anyone decode my VIN please
Hello from Arkansas, and welcome to the "board".
With a small back window, and a 327, it sounds like you have a 1967. The CE part of the VIN says it is a half-ton, as we call them. The normal practice was to put leaf springs on the rear of GMC's, with coil springs as an option.
Inside your glove box door, there should be a decal affixed that will have two columns of characters on the left side of the column with a brief description of that item. For instance C60, U63, M49 are some of those letter/number combos you will find.
If you take a picture of that decal and attach it to one of your postings, we can tell you a lot more about your vehicle.
Member Nr. 2770
Old 07-14-2007, 10:57 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The GMC trucks are funny, nothing like the chevys.
I agree that the small back window makes it a 67.
All GMC trucks had the 4 lamp grills... yours should say GMC in the center of the grill too... that's a 67 only piece.
There's a couple ppl here that know the GMC VIN codes... I'll give it a stab.
CE1590D PC1240A;
C 2 wheel drive
E v-8 gas motor
15 1/2 ton
umm, I'm lost on the rest.
Where's Rod? He knows these
Old 07-15-2007, 08:13 AM   #4
Rod
CE1590D PC1240A
C = Conventional truck cab
E = Eight Cyl
1 = 1/2 ton
59 = Cab to rear axle dimension of 54 inches.
0D = Fleetside box
the space is for the state code designation if required, which in this and most cases is not required.
P = Pontiac Assesmbly Plant
C = model year 1967
1240 is the sequence number of the vin
A = GVW range 6000 lbs or less
Those were the interesting ones to decode when I figured out the GMC vins.
I live in Canada, just north above North Dakota. These trucks sure get around still. Welcome to the boards.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 07-15-2007, 09:31 AM   #5
john64
Thanks for that guys, couldn't figure gmc vin. I used to live in Canada, Oakville Ontario so I guess I get around too. Got somr resto work to do on truck so will post updates. Hardly any serious rust, but hardly any paint left on the truck either.
Cheers
John
