07-14-2007, 07:48 PM | #1 |
65 - Chevy C10
Headlight Bulbs to Buckets
Its been a long time since I disassembled my headlight bulbs from the buckets. Can someone walk me through the steps to get bulbs back into the buckets. I need new alignment screws and cant seem to get ones that fit into the squares properly.
07-14-2007, 08:18 PM | #2 |
Re: Headlight Bulbs to Buckets
I just ordered new screws and stuff from lmc, and they worked great. If u bought new headlights, and they have a rubber seal covering the back, u have to put the bulbs in the buckets first, if there the old ones, then u can do it later. First put the retaining spring in the backing plate, whatever its called, then take the bucket and hook the top of the spring into it. It will be way off angled way up. Push the pucket down into place adn put the alignment screws in. Then just tighten the alignment screws to the desired postion, and there u go. U have to get the retaining ring and three screws to do the bulbs, but thats simple, just put the ring over the bulb and put in the three screws.
Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] |
07-14-2007, 08:49 PM | #3 |
65 - Chevy C10
where does the spring go to? thanks by the way
07-15-2007, 12:06 PM | #4 |
O sry. Theres a little hole in the bucket that the curved end of the spring goes into. I tried to get a pic but it was harder than i thouhgt with them allready installed. I drew a pic to show where the location of the hole is with respect to the adjustment screw points and the holes for the trim ring screws. Hope this helps....
Brad
07-15-2007, 01:47 PM | #5 |
65 - Chevy C10
dude...ur fricken awesome! I had it totally in the wrong spot.
OK, my next question is I see where I can get the left side retainer screw in (according to your diagram). There is a notch to slide it in. However on the opposite side the notch is not there, just a hole as your diagram shows. |
07-15-2007, 05:18 PM | #6 |
Junior Member
What kind of lamps are you running in there Skyline?
07-15-2007, 06:00 PM | #7 |
For the other adjustment screw, there should be a notch and a hole on the same flange like in the diagram up by the top. The two adjustment screws are supposed to be 90 degrees away from one another, then the spring goes almost like 130 degrees away from those.
ol Curt: The lamps are straight from LMC, their like 40 bucks a piece, then they have blue bulbs installed in em... Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] Last edited by SkylineNXS; 07-15-2007 at 06:10 PM. |
07-15-2007, 11:44 PM | #8 |
65 - Chevy C10
hmm.. my adjustment screws are 180 degrees from one another. I have a slot in the bucket for on on each side of the bulb.
Yes, those are nice bulbs. Do they plug up to the standard socket? |
07-16-2007, 01:30 PM | #9 |
My buckets are differnt, but it looks like u got em in, right? In ur other thread for ur hood, looks good man.
Yea i think those lamps plug up. When i got my truck the headlight harness was "missing", so i bought a heavy duty one with double relays from LMC when i got the lamps, somethins still up with my wiring so i still havent seen them working....lol, nice truck by the way salazar... Brad
07-16-2007, 04:23 PM | #10 |
65 - Chevy C10
Thanks. Well I got them in but they are not in correctly. I am missing the right side adjustment screw. I will take a look at them later.
