Old 07-14-2007, 08:05 PM   #1
mrjs80
Remote fill master cylinder
So I want to do an under dash master to clean up my firewall. But that includes it's own set of problems. You have to be able to access the master to fill and check fluids. So I was thinking the best way would be a remote fill reservoirs. There are a few companies that make them but they either have a single reservoir or they don't have the bore size I'm looking for.
I was wondering since I already have a master could I just tap, weld, glue, etc a fitting to my existing cap? One for each reservoir, then cut the middle out of the rubber seal so the fluid would actually get to the plunger. The perimeter of the gasket would still seal the cap to the master. Then just run my lines to where I want (I was thinking under the cowl) and use an aftermarket plastic reservoir.
I really don't see any difference between that way and say Wilwood's way. The only difference that I can think of would be the amount of fluid. You would be filling both the new remote reservoir and the stock one. More fluid shouldn't be a bad thing?
would save some money
mrjs80 is offline   Reply With Quote
Old 07-14-2007, 08:17 PM   #2
mrjs80
Re: Remote fill master cylinder
Something like this
Old 07-16-2007, 10:54 PM   #3
mrjs80
Has anybody done anything like this or have any info.
Old 07-17-2007, 06:46 AM   #4
bb1979
bb1979's Avatar
It can be done but I think that the remote has to mounted at least at the same height or above the master cylinder. The metal master cylinder cap can be drilled and a threaded fitting inserted (can't think of what its called similar to a male compressor hose fitting with a nut on the inside of the master cylinder).
I would be looking at the forward control vans etc the japanese ones they usually have it all jammed up under the dash.
bb1979 is offline   Reply With Quote
Old 07-17-2007, 11:32 AM   #5
69burban
Garage Built Rides
69burban's Avatar
I don't know if you can get them anymore, or if someone else makes em', but I used Turner's under floor setup. It moves the booster and master cylinder under the floor on the frame, with the pedal coming up from the floor. Completely cleans off the firewall, pretty involved, but I like it. Let me know if you need some pics
Albuquerque, New Mexico
65 long bed,
shaved drip rails, tail lights, tailgate, and molding. 350/700r4, dropped springs
69burban is offline   Reply With Quote
