77 to 68 front susp swap?
Hi
I know this has been asked to death,but I cant remember for positive if a 77 gmc front suspension setup will "bolt up" to a 68 frame.I have the chance to get a 77 gmc 1500.The 454 runs(tho with a flat cam not well)and it has all the goodies,tilt,air,ps,pl,pw,power disc brakes(5 bolt) and was wondering if i could use the cradle,arms,brake setup and ps box etc as a direct bolt up? I plan on taking the 454,400 and rallies off it and also the front suspension if it will work.My buddy needs the other goodies for his 75 swb 454.i cant pass it up for $400 with all these nice goodies to use off it. Thanks in advance RaTTrap 68 ![]() |
i got an 80 front suspension on mine all i used was the spindles with 72 ball joints( which i was told on here wont work) in my 70 a- arms and the steering linkage and power steering box..and then used 80 calipers and brake hoses....hope this helps...
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
You can use the whole steering crossmember and the steering gear. The steering gear should just bolt right up to your frame without any problems, however to bolt the whole crossmember in you will have to enlongate one of the holes on the side of your frame. In each side of your frame you will have 7 holes, 3 that are along the bottom and 4 in the side. It is one of the side holes that you will have to enlonggate. The one that it is, is the lower rear one on the side of the frame. I believe that you will have to enlonggate it toward the front of the frame, however I am not possitive. You can set the crossmember in place using the 3 bolts in the bottom to allign it and you will see which way it needs to be done. I have done this with 3 or 4 trucks and it works great. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Thank you,that was VERY informative!!
I am printing this out right now for future referance,I really appreciate the info and time it took for you two to post.It will go alongways to getting it on the road and annoying fellow co-workers. RaTTrap 68 ![]() |
