Old 07-15-2007, 12:48 AM   #1
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Best of 2 trucks on 1 - easiest way?
I have a '68 GMC short bed stepside with the 305ci V6 and 3 on the tree. It has the leaf rear suspension with a 10 bolt open rear end. I also have a '72 C10 short bed stepside that started life with a 6cyl/3sp, but now has a '88 305 V8 with a turbo350 in it. This truck also has the coil rear suspension with a 12 bolt posi.
I want to put the '68 body work (cab, front clip, and bed) together with the V8, turbo350, front disc brakes, 12 bolt posi and rear coil suspension from the '72 truck...then part out the majority of whats left.
So here's the question (and consider the '68 frame is better then the '72's)...would it be easier to pull the V8, turbo350, front disc setup, rear coil suspension, and steering column off the '72 chassis to install it all on the '68 truck (once I'd pulled the engine, tranny, front drum brake setup, column, rear end and rear leaf setup) ....or... just pull the body off the '72 chassis and pull the '68's body off its chassis... then install the '68 body work on the '72 chassis? And deal with the frame swap at a later date when I build up the carb'd 427ci (or 454) LSX (the GMPP iron block), a 5 (or 6) speed tranny, and a performance suspension and brake setup thats all eventually going in?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-15-2007, 02:51 AM   #2
watahyahknow
watahyahknow's Avatar
Re: Best of 2 trucks on 1 - easiest way?
i believe its eaziest to just put the bodywork on the 72 chassis a lot less wrenching required you only have to dissconect the wiring the steeringcolumb the brakestuff and the controlls for trottle and gear the engine brakes transmission and rearaxle with the springs and all can stay on the chassis .
when you want to do a frame off you free to choose anny part you want as long as it fits cause you be taking everything apart for painting and redoing anyway
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 07-15-2007, 08:03 AM   #3
bad6772
Official Site Guitar Shredder
bad6772's Avatar
makes more sence to me to di it that way also
bad6772 is offline   Reply With Quote
