5 lug rear end
not sure what gears im sure they are the factory gears but its complete leaf spring setup 150
![]() Join Date: Jun 2005
Re: 5 lug rear end
where are you in fl? leaf or coil? thanks, dan
Re: 5 lug rear end
leaf spring central flwest coast
Re: 5 lug rear end
can you send me a pic of the housing condition? your location--what city?
Project underway - finally.
Re: 5 lug rear end
I'm in line if you can verify two things for me:
When was it last on a vehicle? Did it make noise at all or anything bad? Can you check the ratio? -Brian
1972 GMC Pre-resto... awaiting allocated funding. |
Re: 5 lug rear end
the ring gear reads 3817779 14:43 gm 10 71 1 never heard it run i bought the truck with out a motor i have done is pushed it around
w314speed the housing is in good shape just dirty located in west central fl just north west from tampa |
Re: 5 lug rear end
PM sent
Re: 5 lug rear end
sold
