oil leaking in cab
i have oil leaking in the cab right by the gas peddle and when you foot is on the gas id drips on your foot
its a 72 |
fugedaboutit
![]() Join Date: Mar 2005
Re: oil leaking in cab
Check your oil seder under dash or where your brake pedal rod goes thru the firewall/ master cylinder..
Currently truckless ![]() |
Official Site Guitar Shredder
these have mechanical oil pressure gauges meaning theres a small diameter metal tube the carries oil from the bck driver side of the engine block thru the firewall to the oil pressure gauge// its leaking
thanks guys
Hellasick
![]() Join Date: Jul 2006
at least you didn't get enough of a leak to burn yer foot!!
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
