Old 04-29-2002, 10:46 AM   #1
white68chevy
Post Torq-Thrust II's
Is there any body that is running torq-thrust II's? If so what size tire and wheel? Thanks
1968 swb
IM-Bufechevy56
1968 swb
IM-Bufechevy56
If its to loud then your to old
white68chevy is offline   Reply With Quote
Old 04-29-2002, 11:54 AM   #2
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
These are 17X8 in front with 4" backspace and the rear is 17X9.5 with 5.5 backspace. With 255/50/17 Bridgestone Potenza RE730's all around. The tread is 9" wide and the tire is about 10" wide
I will have better pics soon
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
WANTED: Drop Spindles
F/S: rebuilt Turbo 400 & Aluminum wheels w/ tires
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 04-29-2002, 01:30 PM   #3
white68chevy
Post
Those look great. You have got yourself a nice truck there. Anybody else?
1968 swb
IM-Bufechevy56
Old 04-29-2002, 03:05 PM   #4
The Blue Pig
Thread Wizard Since 2002
Post
That is a beautiful truck 72. I was also curios and going to make a post about backspacing, did you do measurements for that backspacing, or did they just come like that?
--70 C-10 Longbed
--71 C-10 Longbed
--72 K-20 Longbed
--74 C-10 Shortbed
--86 Toyota Tercel (His Driver)
--05 Chevy Trailblazer (Her Driver)
The Blue Pig is offline   Reply With Quote
Old 04-29-2002, 04:33 PM   #5
SCOTI
SCOTI's Avatar
Post
My 67 has 18x8 w/5.25 b.space in front & 20x10 w/6.0" b.space in rear w/stock width rear end & widend tubs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-29-2002, 06:47 PM   #6
jay6891
Car Knocker
jay6891's Avatar
Post
Scotti, got any pics? That is the combo I'm looking for.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 04-29-2002, 08:08 PM   #7
SCOTI
SCOTI's Avatar
Post
I'm trying to get some digital pics to post. I've got some others but I haven't figured out the scanner to posting sequence yet. What I can tell you is that 4" back space up front would definitely not work on mine(it wouldn't even work w/my 68 beater w/5/7 drop.
[This message has been edited by SCOTI (edited April 29, 2002).]
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-29-2002, 09:27 PM   #8
kurts72
Post
I ordered 15x6 and 15x8s and had to get the 4-3/4" bolt circle since American doesn't sell them on a 5x5" BC with the 15x6. Next week I'm lowering the '72, re-drilling the rotors and rear axles and will be mounting the mags. Really looking forward to the new look.
Kurt in Durand, IL
kurts72 is offline   Reply With Quote
Old 04-29-2002, 11:09 PM   #9
white68chevy
Post
Scoti what size tire are you runin on the back?
1968 swb
IM-Bufechevy56
1968 swb
IM-Bufechevy56
Old 04-29-2002, 11:43 PM   #10
SCOTI
SCOTI's Avatar
Post
Mine are also 5 on 4 3/4 bolt pattern & the rears are 295/40/20's. I don't know if you guys are looking a T.Thrusts or the newer II's but the newer II's have lots of different offsets compared to the originals. Kurts...that should look sweet.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
