Old 07-15-2007, 05:49 PM   #1
rckendal
metal plate
I need help. Buying a 1969 chevy stepside 4x4with a 307 eng. The plate on the inside door frame says c51498839412 what does this tell me. Thanks for any help.
rckendal is offline   Reply With Quote
Old 07-15-2007, 06:00 PM   #2
rckendal
Re: metal plate
cs1498839412
Old 07-15-2007, 06:20 PM   #3
mvfd70
mvfd70's Avatar
Re: metal plate
Go here. http://67-72chevytrucks.com/Chevyear.html
Its a VIN and model number decoder. the number you have is the VIN I think. You should have another letter after the 149 that is probably a B and the next digit should be a 1
CE149J 100001 is there example number
From the information you gave this is what I could get for your number.
cs149B139412 is what the number should be (I would think anyway without seeing it)
C - 2 wheel drive
S - six cylinder engine
1 - 1/2 ton
4 - pick up with bed
9 - 1969 model year
B - Baltimore assembly plant
139412 - unit number 39,412 built in that plant.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 07-15-2007, 06:20 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: metal plate
This may be helpful... I've used it before
http://www.americanclassic.com/paint.htm
68gmsee is offline   Reply With Quote
Old 07-15-2007, 06:57 PM   #5
1969k10stepside
Re: metal plate
It tells you the vin is a 2wd.Meaning its a 4wd convert or 2wd body on 4wd chassis
1969k10stepside is offline   Reply With Quote
Old 07-15-2007, 07:31 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: metal plate
The 8 may be acurate. Any plant that had the same model coming off a second assembly line would start with 700001 as the first one off the line, which would make this truck #139412 off the second assembly line. Being that 69 was a banner year for truck sales, it is highly possible.
68gmsee, that link is giving some wrong info on that VIN. The one on this site (as mvfd70 posted) is the most acurate one I have seen. It is only missing the info i just posted about the second assembly line, and the info for the additional C for a 72 model.
Old 07-15-2007, 09:19 PM   #7
mvfd70
mvfd70's Avatar
Re: metal plate
Interesting info. Thanks for sharing that. I didn't realize that.
Old 07-16-2007, 09:45 AM   #8
rckendal
Re: metal plate
is switching 2 wheel drive to 4x4 common, how is this on a collectors stand point. Just dont want to buy something that is noy worth buying. Thanks for any help.
Old 07-16-2007, 12:03 PM   #9
mvfd70
mvfd70's Avatar
Re: metal plate
They could have added 4x4 parts to make it a 4x4 or it could be an original 4x4 that they changed cabs on. As far as collectors standpoint, in my opinion, thats really up to you. It may not be the original VIN for the truck. If you can, find the VIN stamped on the frame and compare it to the one in the cab. If it's the same then its been upgraded to 4x4. If it's different, someone changed cabs.
Old 07-16-2007, 12:34 PM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: metal plate
The vin on my 69 K20's frame was on top of the drivers side frame rail just a bit behind where the steering box is located.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-16-2007, 12:52 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: metal plate
If the cab has been swapped onto a 4WD chassis, then it should have a different VIN on the chassis. If that is the case, there may be a paper trail for the swap that would legitimize the alterations.
I don't know what your vehicle registrations demand, but it sure bears some watching and explantions from the seller, if you haven't already made the deal.
Member Nr. 2770
