Old 07-15-2007, 07:41 PM   #1
62 short step
62 short step's Avatar
2wd tranny to np205
Okay, so here it goes with the stupid question. Can a 2wd th350 tranny be made to work with a 205 from a 4wd th350 tranny?
62 short step is offline   Reply With Quote
Old 07-15-2007, 08:33 PM   #2
1969k10stepside
Re: 2wd tranny to np205
I converted a 2wd th350 to a 4wd version.I did have a cracked 4wd th350 to use the shaft from though.The alternative is to use a divorced t-case,a 2wd tranny,and a small shaft in between connecting the 2.
1969k10stepside is offline   Reply With Quote
Old 07-16-2007, 02:22 PM   #3
Chris27
Blazerless
Chris27's Avatar
My 72 Blazer had a "converted" 2wd Th350. All the PO did was hack off the end of the output shaft the same length as the 4wd unit. You could see the marks and discoloration from the chop saw. It works but it's kinda redneck.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD
69' Beaumont 388/700R4 11.70@116
77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad.
Chris27 is offline   Reply With Quote
Old 07-16-2007, 06:17 PM   #4
62 short step
Thats what I have now, divorced rockwell. can't find a divorced 205 around here all I can find are ones for th350 or th400. Oh well my search will continue. Thanks, Jeremy.
Old 07-16-2007, 06:18 PM   #5
62 short step
I guess if it works it works It is kind of redneck though Thanks, Jeremy.
Old 07-18-2007, 02:56 AM   #6
Wreckless_71
Wreckless_71's Avatar
I've heard of stories of the "good ol' days" when they used to cut the tail shaft down on a 4l60E to make it fit into an NP 205... but remember, that was the good ol days!
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 07-25-2007, 09:59 PM   #7
xshadow
I have known people that have cut about 2" off and it works well
xshadow is offline   Reply With Quote
