Old 07-15-2007, 09:04 PM   #1
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
Thumbs up **SOLD*1969 GMC 1/2 Ton, 2wd, 5 bolt 5on5 axles, leaf rear Ring, Pinion, Posi Carrier
SOLD TO suville
I have completed the rear end swap in my truck. The swap was done to get longer legs on the highway, from a 3.73 to a 3.08.
Now for sale is the replaced Ring, Pinion and Posi Carrier. I had no trouble with this setup- ran quiet and smooth, no noise, no metal in the oil when removed.
*** I MAKE NO WARANTEE ABOUT WHAT THIS WILL FIT! ***
The bearing races are stamped:
Made in USA KX NDH LM603812
The pinion sleeve is unmarked
The pinion is stamped:
3884335
11:41
12 69 GM
The number 4 is marked in crayon or paint
The Ring / Pinion is stamped:
30060
188 or 881
A??A STE?L
ED
a circle with a cross inside and a 1
3817778
11:41
12 69 GM
4J
J B or 3 K
*** YOU are responsible for making sure this fits your truck! ***
I have seen several posts that say the 12 bolts are all the same inside. THIS IS NOT TRUE. I bought what was advertised as a 2.92 that would work in my truck. It did NOT. My understanding of the two ring/pinion sets that were/are in my truck is that the 3.08 and lower gears are a smaller size than the 3.73 and larger gears. The 2.92s ended up being 3.08 and required a new carrier ($450 from Randy's Ring and pinion). No bargain after paying $150 for the ones that don't fit.
I will post pics in a couple of hours.
I am looking for $300 plus shipping estimated at $75 via UPS. As always if shipping is less overage will be refunded.
Will consider trade for Holley 4160 750 CFM vac second, w/electric choke in near-perfect condition
or
Holly Street Avenger 750 CFM, w/electric choke in near-perfect condition. Not interested in anything else.
All communication here in this thread please- NO PMs will be answered until after sale.
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 07-15-2007, 09:28 PM   #2
suville
suville's Avatar
Re: 1969 GMC 1/2 Ton, 2wd, 5 bolt 5on5 axles, leaf rear Ring, Pinion, Posi Carrier
Dave ,Put me in to bat. Depending on what ya got (pics) might take it. BTW hows my hood storin? Cya in Sept.
suville is offline   Reply With Quote
Old 07-15-2007, 09:43 PM   #3
WinDancer
WinDancer's Avatar
here are the pics.......
Dave
Old 07-15-2007, 09:46 PM   #4
WinDancer
WinDancer's Avatar
And more..............
Dave
Old 07-15-2007, 09:49 PM   #5
WinDancer
WinDancer's Avatar
had to size these down...
Dave
Old 07-15-2007, 09:51 PM   #6
WinDancer
WinDancer's Avatar
I checked everything I could while wiping the parts down- there are no cracks or chips or wear spots or other foreign marks on anything.
I believe the new owner will be very happy when they get this installed, specially if you are replacing a one legger
Dave
Old 07-15-2007, 09:53 PM   #7
WinDancer
WinDancer's Avatar
Hey, suville, nice to hear from you. Hope all is going well for you and that you get home as expected.
Your new hood is doing fine, waiting patiently in the dry back shed.
best regards!
Dave
Old 07-15-2007, 09:54 PM   #8
WinDancer
WinDancer's Avatar
suville is first in line.
Dave
Old 07-16-2007, 09:20 PM   #9
WinDancer
WinDancer's Avatar
Still available...
Dave
Old 07-17-2007, 10:31 PM   #10
WinDancer
WinDancer's Avatar
Price reduced: 280 plus shipping
Dave
Old 07-18-2007, 12:27 PM   #11
WinDancer
WinDancer's Avatar
Sold to suville- Thanks!
Dave
Old 07-19-2007, 12:27 AM   #12
WinDancer
WinDancer's Avatar
Sold!
Dave
Old 07-19-2007, 05:58 PM   #13
WinDancer
WinDancer's Avatar
Re: **SOLD*1969 GMC 1/2 Ton, 2wd, 5 bolt 5on5 axles, leaf rear Ring, Pinion, Posi Carrier
Suville, if there is any problem with this fitting your rear end I will refund the full amount. See you soon,
Dave
Dave
Old 07-19-2007, 06:42 PM   #14
suville
suville's Avatar
Thanks Dave, If it came out of a 12 bolt truck rear it'll work Im sure. Want this for my 292,700R4 powertrain ! Just picked up a sweet 69 burb with a Cad 472 swap anxious to get started on it , was building one but circumstances dictated moving on got another complete 68 472 with about 40 thou on a complete factory parts rebuild edelbrock intake sum other fun stuff cant beat raw torque! Been watching frizzle frys and wess build with interest!
